piHPSDR on Windows
Aivars
piHPSDR on Windows
Postby Aivars » Sun Jan 15, 2023 12:06 pm
Hello! I would like to inform, there are Windows version of piHPSDR available 8-) Vladimir EW8BAK in cooperation with Yuri EU2AV adapt it for Windows. Most fresh info will be available here:https://eu2av.ru/viewtopic.php?f=13&t=157&p=907#p907
Github with source code: https://github.com/ew8bak/pihpsdr
Short instruction: first of all you need to install the gtk3-runtime-3.24.31 library, then open the PihSDR_bin folder and run the pihpsdr.exe file, after which the installation will begin. Next, go to the network settings, and create a rule for incoming and outgoing connections.
Instructions are on Github as well. I attached installation file. GTK Windows library you can download here https://github.com/tschoonj/GTK-for-Windows-Runtime-Environment-Installer/releases/download/2022-01-04/gtk3-runtime-3.24.31-2022-01-04-ts-win64.exe
By the way, work on linHPSDR on Windows are underway as well 8-) I will inform about progress ;)
pihpsdr.rar
(2.7 MiB) Downloaded 149 times
YL2GVC 73!
Re: piHPSDR on Windows
Postby w-u-2-o » Sun Jan 15, 2023 12:57 pm
What is the advantage of running piHPSDR on Windows vs. running Thetis?
Aivars
Postby Aivars » Sun Jan 15, 2023 3:34 pm
I just share info ;) I guess it is funny toy. No advantage over the Thetis, IMHO.
YL2GVC 73!
DL8LAQ
Postby DL8LAQ » Sun Jan 15, 2023 5:09 pm
Aivars wrote:I just share info ;) I guess it is funny toy. No advantage over the Thetis, IMHO.
Yes, it's just fun and it works :-)
Cosmo1stgen
Postby Cosmo1stgen » Mon Jan 16, 2023 5:03 pm
While this is very cool and I will likely play with it in addition to thetis on windows :D I hope that during or after the port the inherent problems or "bugs" that pihpsdr and linhpsdr can be fixed at the same time and maybe add some features. Maybe being on windows will help with that because of the sheer number of users but I dont think many will sway from thetis. I run pihpsdr linux now becuse other than quisk it is the only other somewhat stable option for our radios on linux. I have had nothing but problems with linhpsdr. I run dual boot machine now and can operate in both OS.
Ryan
KK6DZB
vk1hx
Postby vk1hx » Mon Nov 20, 2023 2:31 am
Sorry for *bumping* and old thread. I've been playing with this mod config and it works easy. Does anyone (who has either developed this or uses it) know how to make piHPSDR (this version setup) window bigger for larger screens?
73, Phil - VK1HX
Return to “piHPSDR”
