G2 PiHPSDR NOTICE
n1gp
G2 PiHPSDR NOTICE
Postby n1gp » Sat Oct 21, 2023 11:30 am
(This is a re-post from the G2 S/W & Apps discussion)
Hello fellow G2ers.
Christoph / DL1YCF, who has been actively maintaining and enhancing John's / G0ORX
wonderful program PiHPSDR, has merged in all of my Saturn PiHPSDR code to his repo.
Please follow the procedure below to update your git repo to point to his.
Also, please direct general PiHPSDR issues to him when using his repo.
I don't think he monitors this forum often so you may try him at DL1YCF@darc.de
If the issue is Saturn PiHPSDR related, please let me know. I monitor this forum very often
or n1gp@hotmail.com
NOTE: The github repository URL for G2 PiHPSDR has been changed from
https://github.com/n1gp/pihpsdr
To
https://github.com/dl1ycf/pihpsdr
To see which URL yours is pointing to:
1. Open a command window
2. Type cd github/pihpsdr
3. Type git remote -v
If your URL is https://github.com/n1gp/pihpsdr you will need to change it.
To change it (which only needs to be done once):
4. You should still be in directory: github/pihpsdr
5. Type make clean
6. Type git checkout master
7. Type git remote set-url origin https://github.com/dl1ycf/pihpsdr.git
8. Type git pull --rebase
9. Type git checkout RELEASE-2.2-DL1YCF
Then
10. Type make -j5
If you are asked for your name and email:
Type git config --global user.email "you@example.com"
Type git config --global user.name "Your Name"
You should check out the excellent PiHPSDR manual Christoph has written which
is also in his repo:
https://github.com/dl1ycf/pihpsdr/blob/ ... Manual.pdf
K6JR
Re: G2 PiHPSDR NOTICE
Postby K6JR » Sun Oct 22, 2023 9:00 pm
Good Job!! Really cleaned up the receive audio on my G2. I have the G2 with the display and knobs. Is there a setup to make it work with the knobs on the radio? Right now I am just using the sliders.
Tnx, Jim K6JR
Return to “piHPSDR”
