![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
ramdor wrote:UPDATE - (3/1/20) (a2)
- fix: path illustrator not working for 100B + 200D radios
ramdor wrote:Just a teaser. Should be done by sometime over weekend.![]()
wa1oxt wrote:Hello Richie ,
Is it possible to repair the Mic slider (Main Gui) and Mic/Gain/Sources (Setup>General>Transmit ) so they operate in VAC1 .
I miss that feature which was operational in MRX.
Hi Bryan,Bryan W4WMT wrote:That said, the new ASIO CODEC will be fully operational from the main console (MIC, MUT, Master Gain, etc); i.e. it will operate exactly like the hardware CODEC in the radio, but runs through ASIO instead (and later WASAPI) without the help of PortAudio. ATM it's not working glitch free without a small (192 sample) ringbuffer sandwiched in between the ASIO driver and Thetis' ChannelMaster, which kind of defeats the purpose of eliminating PortAudio in the first place. So we're still thinking of ways to better synchronize the Audio Mixer & MIC streams to patch the ChannleMaster directly into ASIO's double-buffer callback.
W2SDR wrote:I’m getting the same Andromeda error message here.
Frank, W2SDR
I’ve tried setting to “none”. No luck
w2ner wrote:okay, I'm going to sound stupid but what is Andromeda? It sounds like some type of game controller.
w2ner wrote:thanks Gary. i saw that some time back now that i read it again. so it’s not a product yet so why are there posts about it in this thread ? am i missing something?
Frank, W2SDR
W2SDR wrote:my database:
Thetis_database_export_3-13-2020_6.23 AM.xml
W2SDR wrote: Also all of the PA calibrations had changed when going to 2.7.0 .
W2SDR wrote:Those CAT + com ports used because they worked fine with the previous versions. Also all of the PA calibrations had changed when going to 2.7.0 .
