Some info regarding this error :
![and_error.png](./download/file.php?id=1092&sid=6b6e4254ae8bf6031e28178323f5cd6a)
- and_error.png (9.85 KiB) Viewed 18917 times
After some extensive testing and investigation, I can only assume the people that are seeing the Andromeda error are doing so because they are using the
incorrect version of ChannelMaster.dll along side their Thetis exe.
ChannelMaster.dll includes a new call ATU_Tune. If that is not found in the dll then an error will occur during the andromeda enable/disable code and result in message you are seeing. It is impossible to see it any other way, especially after looking at the database.xml file provided.
I have checked the a2 zip file, and all correct files are there. If you are using these test versions, please make sure you follow the info in post number 1, especially the bold text.
There is nothing more I/we can do with this error as all looks ok in the code, and the only way I can get it to present itself is to use the wrong version of the dll.
Going forward, there is a case for including a version number in all the external components (dlls etc), that will get reported during an error/exception.
