g4bim wrote:Radio won't transmit or receive above 30.0000 mHz after going to 2.8.11.
Anan 7000 dle i7
Ver 2.7 firmware
Any ideas ???
G4BIM
Try resetting your database, or completely deleting your settings folder.
Anan 7000 dle i7
Ver 2.7 firmware
Any ideas ???
G4BIM
K0MO wrote:Thanks for the update!
I'm running the latest Thetis 2.8.11 x64 version.
Everything seem to be working fine for me on my Anan 100B running protocol 2 firmware 10.3, except PureSignal runs very unstable, unreliable and distorted compared to protocol 1.
I did revert to protocol 1 firmware and can confirm that PureSignal works flawlessly there, but I rather have the features and performance of running on protocol 2.
Can this be fixed?
Anan 10e and 100b are the only radios that haven't received any firmware updates for over two years compared to other models.
They need some love because they're great little compact radios!
Manny K0MO
N9VX wrote:Running Thetis 2.8.11 x64 on ANAN-100B protocol 1 (version 1.3) using W10 x64. Dell i5 desktop 8 gig ram, SS drive. 1 gig switch between radio and computer.
Random bad SSB TX audio reports, most TX is good, then a bad transmission occurs. Told it has a distorted echo sound. Has happened on various bands.
Did a database reset, still problem (random).
Tried Thetis 2.8.11 x86 with same results.
NOTE: mRX ,with everything else the same, has never had this problem.
On one occasion it was also reported I was wide, went to mRX and it cleared up, was running Pure Signal in both (all) cases. Guess I should try with Pure Signal off, but for now I am back to mRX.
Joe N9VX
w-u-2-o wrote:That number is supposed to represent the amplitude and location of the largest signal in the spectral display window. I never notice it because I always have PureSignal turned on. But I tried it and the amplitude measurement does seem broken.
Does anyone actually use this data to run their radio? It doesn't seem very useful. I'd just as soon have not displayed.
I4LEC wrote:Same issue as N9VX on my ANAN10 (16bit) running Thetis 2.8.11 P1 using W10 x64. i7 desktop 6 gig ram, SS drive.
Did try deleting the file wdspWisdom00 and regenerating it with no joy.
It seems linked to PS as without it or single cal it works fine, it happens randomly 1 every 12-15 ptt
73, Clay
K1LSB wrote:Not sure if this is the proper place to post this, but I can't seem to make the RX EQ work for RX2.
Am I doing something wrong or is that a bug?
