vk1hx wrote:...Scott...
Phil - VK1HX
P.S. do you have a position/explanation/idea on my issue with powering Thetis 21f off then back on and it closing?
Phil, I've noticed this as well, and it started with earlier 21 releases.
Phil - VK1HX
va3cxp wrote:vk1hx wrote:...Scott...
vk1hx wrote:Some further testing done today. It seems to be isolated to running Protocol 1 (P1) firmware.
I was testing some new Protocol 2 firmware today and Thetis didn't shut down on powering on again. I reloaded the P1 firmware is the issue is back. Hopefully this information offers some areas to look at in the Thetis 2.8.11 (21 series) application.
Cheers
Phil - VK1HX
ramdor wrote:just a follow up on the P1 power down crash. Does it all just vanish? or is there a crash message box that pops up?
Also, could you check to see if ErrorLox.txt file exists in C:\Users\<you>\AppData\Roaming\OpenHPSDR\Thetis-x64 or \Thetis
and if so, attach to a message or include the very end of it after a crash/shutdown
Cheers
vk1hx wrote:ramdor wrote:just a follow up on the P1 power down crash. Does it all just vanish? or is there a crash message box that pops up?
Cheers
Thetis just closes, it pauses for a second then closes. There is no error log file either. I check for this and noted it in my earlier post.
DH1KLM wrote:Pls check your skin folder if chk2TONE-0.png and chk2TONE-1.png are present.
oe3ide wrote:There are some infos about these buttons on the top of this thread. Anyway just copy chkMOX-0.png to chk2TONE-0.png and chkMOX-1.png to chk2TONE-1.png and all is good
Alternatively, you can also use one of my skins.
DH1KLM wrote:I made 2Tone buttons for the following skins. IK3VIG Special, OpenHPSDR-Gray, W1AEX Dark Metal, W1AEX High Visual.
They can be downloaded as a zip file from https://drive.google.com/file/d/1eELS_GHAhLcrzX5SDQjnXr6NGUUarIl7/view?usp=sharing
You only have to copy the contained button pics into the corresponding skin directory.
Usually at C: \Users\ yourusername\AppData\Roaming\OpenHPSDR\Skins.
I hope to be able to help someone with this.
va7qi wrote:Found a bug when using the Andromeda display format. When clicking on Antenna it correctly switches to antenna#2, but another click does nothing.
73 de va7qi, ....Erik.
ramdor wrote:Hi Erwin,
When I do that test, when off MOX rx2 returns to expected att and signals return to where expected. So not sure what is happening there Erwin, odd. I am sure people would have reported that with a 2nd antenna using rx2 and everything dropping down when coming off TX.
However, there does seem to be an issue with the TX ATT being applied even if the checkbox is off. After a quick test the issue also exists in 2.6.7 (29th Apr 2019). Not sure yet if this is just a visual thing or actually happening at the radio.
