Thetis command line start options
is there an option to start Thetis with directly activating the radio without clicking the "start"- button?
TNX
Volker
DL4ZBG
TNX
Volker
DL4ZBG
Re: Thetis programm start option
is there a list of all possible start options available? I did not find it the Thetis manual.
Volker
Volker
-autostart (powers on the radio 2 seconds after thetis start up)
-dbfilename (lets you define a path to a database file)
-datapath (will let you supply a folder that is different to the normal %appdata%\OpenHPSDR\\Thetis (or Thetis-x64)
the formats need to be something like :
for example, my shortcut would be....
Spaces are important between 'arguments' as are quotation marks around arguments that have spaces in the path. The Thetis shortcut might already have quotation marks around that part. Leave those, move to the end (outside the quotations), add a single space, then either the argument, or a quotation wrapped argument.
Code: Select all
Thetis.exe -autostart
Thetis.exe -datapath:c:\thetisdatafolder\
Thetis.exe "-datapath:c:\test with spaces\"
Thetis.exe -datapath:c:\thetisdatafolder\ -autostart
Thetis.exe "-datapath:c:\test with spaces\" -autostart
Thetis.exe -dbfilename:c:\folder\database.xml
Thetis.exe "-dbfilename:c:\test folder with spaces\database.xml"
Code: Select all
"C:\Program Files\OpenHPSDR\Thetis\Thetis.exe" "-datapath:c:\test with spaces\"73
All clear, TNX
combined into post above
Should make some sense adding this usefull information to the Thetis manual !?
Re: Thetis command line start options
Great topic. Edited the title to make it more clear, and made it "tacked".
Would nice to have a "thetis -help" to show the options.
Simpler than a manual.
