ramdor wrote:@Cory K9CDR, sounds like your DB is slowly becoming corrupt somehow, especially If you have lost filters etc in previous updates. Are you holding ctrl each time when updating the version (only needs to be done if moving from tapr 2020, or any version prior to 21f)? If you are, then perhaps I need to spend some time checking the db update procedure as I have not run it for ages now.
Yes, I have held control down when starting Thetis after unpacking the zip into install folder and replacing files with same name and got the same popups about using database from older version and restarting it again after that but without the control key that time. I initially updated from the basic 2.8.11 (10/22/20 or whatever date build that is) and had no issues from that. it was somewhere around rc2 I think it was that I lost receive filters and this most recent one rc4b where i changed the radio to HERMES.
Thank you for all the hard work you're putting into this!!!! I love it
