I’m new to the community! I’m wondering why there isn’t a way to add in mice low end on FM and why it cannot be allowed to be passed through while on semplix mode?
I would like to see an option where you’re allowed to do that to allow those nice Low end frequencies through that I know pass through on AM/ SSB.
THANKS!
Dan
W7ZAR
FM Tx Audio below 300hz cut off on semplix
Re: FM Tx Audio below 300hz cut off on semplix
Simplex
Interesting question. This would be on 10M FM, right? I wonder how many radios allow for the CTCSS receive filter, which cuts off at 300Hz, to be disabled? Thetis allows that on receive (in Setup > DSP > FM), do any other radios?
Assuming that TX CTCSS is disabled in Thetis, are you certain it is filtering TX audio at 300Hz? Have you listened on a radio that is known to be able to receive below 300Hz? I've never tried this myself and I'm not sure I do have a way to try it here.
Self monitoring on FM is almost impossible due to the effect that desense has. I tried messing with wide band FM audio quality years back and unless you modify a receiver, most have the high pass filtering for the PL range.
I basically just let it go with basic audio cleanup and left it alone.
What I didn’t try was recording from the audio output of a second receiver and that would work much better if you could move the receiver out of the near RF field.
When I want to hear how I sound I tap into the antenna output with an RF sampler and feed that into an SDR dongle running in Simon Brown's SDR Console and record the audio then play it back.
w-u-2-o wrote:Simplex
Yep, I’ve tried! And it still sucks on the audio! On RX and TX
kc2rgw wrote:Self monitoring on FM is almost impossible due to the effect that desense has. I tried messing with wide band FM audio quality years back and unless you modify a receiver, most have the high pass filtering for the PL range.
I recorded it on thetis but it still sounds pinched off no HIFI sound like on AM and SSB
I have confirmed that the limiting factor is the TX pre-emphasis filter, which is set to 300-3000Hz as per the de facto industry standard.
Question for @W7ZAR -- how many people do you think would benefit from making a change to this? How many communications radios have the capability to extend the receive passband below 300Hz when in FM mode?
I'm certain the ICOM ID-5100 will receive audio below 300 Hz, I have mine running the receive audio thru VM Potato and I have to add a low-cut filter to get rid of the 110.9 CTCSS tone everyone in our local simplex group employs to block out a local quarmer.
I don't hear the tone when listening on the 5100's tiny built-in speaker but I hear it when listening thru the rear audio output jack.
Edit: Corrected model to ID-5100
honestly not many radios even the Apache radios.w-u-2-o wrote:Question for @W7ZAR -- how many people do you think would benefit from making a change to this? How many communications radios have the capability to extend the receive passband below 300Hz when in FM mode?
