Update v2.10.3.4-pre-release-5 on githubhttps://github.com/ramdor/Thetis/releas ... -release-5TX scope fix, and additional option for midi control ID. You can now combine Control#, channel, status and use as the controlID. This should help fix the K1cue and RightWheel issue on DJControl Compact devices if used (referenced here
viewtopic.php?f=33&t=3488#p12170)
v2.10.3.4 Change Log
[add] show on startup options for ampview and linearity/ps window. Set in the linearity/ps window
[add] can now ignore 14bit Midi messages. More devices should work. Option in Setup->Serial/Network/Midi CAT->Midi
[add] can now combine midi control id, channel and status to be used as the control ID. This should allow devices that share controlIDs for multiple buttons/sliders to work. Options in Setup->Serial/Network/Midi CAT->Midi
[add] certain skins might make it snow !
[fix] scope should now work when in TX
[fix] mic phase reverse now calling correct function in WDSP, and can be turned on/off
[fix] Hercules DJControl Starlight midi device is now better handled. Wheel finger press for example are ignored. If you used this device before you will need to reconfigure as the control IDs will have changed
[fix] PortAudio #850 fix included
[fix] FM should now use low/high cuts. Carlson's rules used for filter width display in FM rx and tx
[fix] Andromeda ModeSpecificForm shouldn't now clear on console resize
[change] tweaks to waterfall agc to minimise screen wide pulse on T/R
[change] waterfall low/high step sizes lowered to 5
