Transmit Record ability lost (since fixed)
There was a build of thetis, perhaps it was a fork one of you made, that fixed the record on transmit when using VAC. Do any of you still have the source for this function? Not sure who fixed it. Thx
Last edited by dynamicfusion on Wed Jan 03, 2024 12:10 am, edited 1 time in total.
Re: Transmit Record ability lost
record and play back work fine in the latest thetis 2.10.35.u2 you have to have bypass vac for recording playback checked for it to play , 73 n8obu
Thanks for the reply, however I believe you misinterpreted what I'm getting at. There was a version not too long ago within the past several months that I was using, I don't believe it was one of Richie's but perhaps it could have been, that allowed me to record myself the same way I can record others and play them back equally. If I remember correctly it was hosted on Steve's GitHub
I made some changes and have built a work in progress build. Please try https://github.com/ramdor/Thetis/releas ... 10.3.6-dev
How cool is that! MIC Audio pertaining and including VAC audio IN ya? Will test later tonight when back in shack.
You can now record your own audio signal, with and without EQ or CFC.
If you record audio with MIC, you hear your audio without EQ or CFC and with Transmitter Output I/Q you hear yourself as others hear you.
So press PTT, start REC, stop REC and then press PTT and Play to play.
The audio assessment is better than via monitor.
Great, thanks Richie!
It would be nice if it would turn on TX directly on PLAY and go on air.
- 2023-12-30_20h47_46.jpg (15.97 KiB) Viewed 2786 times
Most awesome! Running the 2.10.3.6 "dev" version just posted by Richie.
No change selecting either recording to MIC Audio or to Transmitter Output IQ.
Press MOX (or VOX) and then press REC button.
Playback by pressing MOX and Play buttons. Perfect monitor playback using studio monitor speakers.
Turn off transmit equalizer and/or CFC. The playback audio accurately portrays the transmitted audio with these modifications. Great way to evaluate the effect any of these adjustments on the transmitted audio.!!!
Thanks! I've wanted to be able to do this since first using Thetis 12 months ago. What a great tool to discover those "perfect" equalizer and CFC settings!
Running G-2 Anan for past 6 months. Keeping the 7000DLE Mark3. Hoping I can find compatible version of 2 protocol firmware for my Mark3 soon.
73 Torrey N9PY
73 Torrey N9PY
This works very nicely Richie and as others have already said it makes setting up TX audio for your profiles a breeze.
Thanks for all the bug fixes and amazing features you have brought to Thetis in 2023 and all the best to you for the new year!
ramdor wrote:I made some changes and have built a work in progress build. Please try https://github.com/ramdor/Thetis/releas ... 10.3.6-dev
Yes indeed, this change made the record/playback function much better. It was usable before, but I wasn't quite coordinated enough to make it happen reliably. This is perfect!
Cant seem to find the record options control ? What tab is it located on please ?
Tony EI7BMB wrote:Cant seem to find the record options control ? What tab is it located on please ?
Thanks Ernst
Re: Transmit Record ability lost (since fixed)
I finally attempted to make this work. Here is my result with a quick play. Am I transmitting 40k wide? Also, there is no way to play from the playlist. Loop does nothing.
The whole Wave File Controls seems to not function properly. Contesting was not efficient from this radio.
I was assuming that this was like a memory playback feature like Icom and Yaesu have, but the playlist plays all files and there is no way to just play one, then a different one for contesting. I would like to have some memory buttons for playback of call sign and then exchange, etc.
Here is my sample of TX 40k wide.
https://youtu.be/tGrZF1Y9XE8
Nope, I listened on another radio and there is no TX.
You have to key the radio before starting the playback.
oe3ide wrote:You have to key the radio before starting the playback.
It does not play anything when the radio is keyed up.
https://www.youtube.com/watch?v=FRKBSIjuA-Q
