I see there is no button for Alex on Thetis nor can I find a way to turn "Alex" off. By Alex, I mean firmware control. With our old software turning off Alex (pressing the "Alex" Button next to Mox) disabled firmware control but without the button I can't seem to find a way to do it. I need to disable firmware control since I run an 8000 board but have the old 200D PA and antenna switching which has some different select sequences for 80 and 40m than the 7/8000.
Anyone know how to get out of "firmware" control with the latest Thetis? I did see that if I select another "radio", say 7000, then select the 200D again in General H/W Select, it seems to come out of firmware control until I try to select a different frequency then I hear a relay click and I'm back to no receive on 80 and 40m. If there is no way to get out of firmware control, this is a definite no-go for me.
Joe W4WT
Alex and Thetis
Re: Alex and Thetis
Joe,
AFAIK, there is no longer a "firmware" control mechanism in Thetis/P2 firmware. IMHO this is a welcome change and the way things ought to work, as the operator should always be in full control of the preselector state.
I do, however, wish there was a button that would allow changing between preselector OFF (bypass) and ON states.
It would also be SUPER handy to have some sort of preselector annunciation on the main console that showed what BPFs and LPFs were currently in place.
At any rate, in Thetis/P2 all control of preselector and LPF states is now found exclusively in Setup > General > Ant/Filters.
Re: Alex and Thetis
Gentlemen,
I did add the function of HPF disable (Alex disable) to the main screen, I also added a few more functions to the source code regarding the expanded window. I forwarded the changes to Doug some time back on the Alex disable but have not forwarded the latter additions. I also put in the code a function that the filtering is disabled when the “wb” button is selected. I hope in the future I can or someone else could install the function of automatically disabling the filters when the panadapter is selected at a large frequency swath. I am fairly a new learner in the code so I hope Doug check these additions out. I have been using these changes on my 8000 for quite some time and all seems good.
73’s
73’s
Re: Alex and Thetis
Joe, thanks so much for your effort! I have been contemplating the hardware changes I would need to make on the 200D PA board to accommodate 80, 40, and 30 meters under firmware control and didn't really want to do them so maybe I won't have to if Doug adopts your code. In the meantime, I'm back to protocol 1.
The current Thetis Beta seems very close now and has a lot of very nice features that are quite desirable. It obviously represents a lot of work and I commend the developers! In addition, v1.3 of the P2 firmware seems to be a big step up and I did not have any of the previous problems that were in 1.2 running it.
I hope Simon's code has a method to disengage firmware filter control too. I haven't seen it yet so I don't know if it does or not. Perhaps I should ask to get on the beta list to check that out.
Joe W4WT
Joe W4WT
Re: Alex and Thetis
Just to be clear: there is NO "firmware control" mode for preselection or LPFs in Protocol 2 firmware. It is wholly controlled by Thetis.
Re: Alex and Thetis
Ok, Scott, got it. The problem is still the fact that Thetis is doing EXACTLY what the firmware did using Protocol 1 with Alex ON as regards filter selection. What Thetis is NOT doing is honoring the selection of 200D in the Hardware selection menu as regards filter selections and instead, I assume, reading the firmware and seeing that it is Orion MKII and setting the filters according to that rather than the 200D selection. We can call it whatever we want but that is the issue for me.
Re: Alex and Thetis
Joe wrote:Gentlemen,
73’s
Is there any progress on this? I am running Thetis on a 7000DLE with almost no issues, but I sure miss the ALEX button.
Ernie
W2FMU
Re: Alex and Thetis
Ernie wrote:Joe wrote:Gentlemen,
73’s
Ernie
W2FMU
Ernie,
On 3.4.9, do you notice Alex effecting anything else besides what its designed to do, with it off? Just wondering the need to turn it on and off. I always left it on and couldn't notice a difference when it was off. I don't even get spurious emissions from an AM radio stations transmitter site that's less than 2 air miles from my QTH. It is only 1000w though. Only issue I've ever had with a broadcast station was a very strong 40m shortwave station that was hitting me with a -11dbm signal (+60db or s9
![Shocked :shock:](./images/smilies/icon_eek.gif)
Any insight from anyone else as well would be greatly appreciated.
Perry
W3MMR
Re: Alex and Thetis
The pre-selection (bandpass) filtering in the ANAN series of radio hardware is, I believe, only a 3-pole design. Therefore the selectivity ("Q") of these filters is not terribly impressive.
A good way to demonstrate this to yourself is to use the WB (wideband) display feature of Thetis and select different filters manually.
To obtain noticeably good performance from a preselector one needs to be using 7-pole filters with descent Q.
Because the pre-selector performance is so minimal in the ANAN series radio hardware I have disabled it so that I don't have to worry about fussing with it when running RX1 and RX2 on different bands.
Re: Alex and Thetis
Perry,
I turn ALEX off when I listen to 2 different bands on 1 antenna (RX1 & RX2). I turn it on when my neighbor is transmitting during contests as he modulates ALL bands. It works well for this. I really miss having the control on the user interface. Having to go into setup each tie is a big (and unnecessary) step backwards in my opinion.
W2FMU
W2FMU
Re: Alex and Thetis
Ernie wrote:Perry,
W2FMU
Ernie,
Understood. See I dont normally listen to multiple bands on the same antenna, nor utilize the second receiver much at all, and in your situation with Sherman being so close to you, that makes sense. I could see how having to go into setup each and every time could be quite annoying.
Perry
W3MMR
Re: Alex and Thetis
I know you have the 8000 ... doesn't it have preselectors on each RX? You made the comment if you are using both RX1 and 2 you leave Alex off - but if indeed there are independent preselectors this would not be necessary - what am I missing?
Re: Alex and Thetis
Hi Gary,
What you say is only true under certain circumstances. Remember that the term "RX2" in the context of our radios is a highly variable thing. If you equate RX2 to ADC2 (or ADC1, depending on whether you start counting at 0 or not
) then, yes, you are absolutely correct. This is also true for the 7000, it too has separate preselector banks for both ADCs.
However, if RX2 is merely a DDC/spectral display/demodulator (controlled by VFO B), then that point of view might not be correct. And this is how I prefer to think of RX2.
As it happens, because I only have a single antenna for receive, I assign both RX1 and RX2 to the first ADC. I don't use the second ADC for anything right now. Hence in my setup both RX1 and RX2 must fight over the first ADC preselector in that context.
See also this thread.
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
Re: Alex and Thetis
Ah yes - I should have realized that was what you were referring to. Thanks.
