I use a old machine that usually are at 50% load with the basic radio programs, it will love the DX change
![Razz :P](./images/smilies/icon_razz.gif)
Thanks a lot.
EA1DAV wrote:Hi, very impresive all the work Richie. To check the files you upload to dropbox is there any trick?. My tentatives to install it always get some error and I can't test the versions. I use the oficial 2.6.8 ( 9/10/19).
I use a old machine that usually are at 50% load with the basic radio programs, it will love the DX change![]()
Thanks a lot.
ramdor wrote:nico wrote:Hi Richie
Thanks for your fantastic work on version 2.6.8 - the UX is so much smoother and better now and I have started enjoying using the software and my anan again.
I am controlling the VFO via CAT commands and an external controller (TM2). Despite selecting the CTUN button the waterfall is smearing when changing frequency.
I do not get this issue with the waterfall moving/smearing when I use a Midi controller and select CTUN or when using the mouse and selecting CTUN
Unless there is an option that I am not selecting correctly I suspect that this is a bug - would it be PLEASE possible to look into this and replicate how CTUN works when changing frequency via Midi/Mouse?
THANKS
Nicholas
Hi Nicholas,
I have added an option and made the changes.
I literally can't keep up, either!ramdor wrote:However, Doug has just done an update on his personal github pages, and an alpha release install is here :
https://github.com/w5wc/Thetis/releases ... t19_c2.msi
Remember to backup your database
vk1hx wrote:I thought the download package from w5wc repo contained C2 updates? I have noticed the Thetis exe in the C2 dropbox package is larger than the Thetis exe from the w5wc download. Everything else looks similar, the background picdisplay is there, not sure what else would be missing?
Cheers all
W3MMR wrote:One thing I did notice is that when the spectrum gird is aligned to the right on the panadapter, almost half of the numbers are chopped off. Its not that way when aligned to the left. Ive attached a screenshot.sdsd.PNG
Perry
W3MMR
Tony EI7BMB wrote:Thanks Richie . Just one small glitch, on re start the program does not retain the previous window size used
Tony EI7BMB wrote:Thanks Richie , not a big deal as it takes seconds to fix at this endI'll update the .exe
ramdor wrote:Tony EI7BMB wrote:Thanks Richie , not a big deal as it takes seconds to fix at this endI'll update the .exe
updated link again Tony![]()
Ernie wrote:Richie,
>change: tx profile changes with mode (direct code port from powersdr)
This is not working here in c3.
W2FMU
Ernie wrote:Richie,
W2FMU
Helmut wrote:Hi all, it´s getting better and better![]()
One thing that i do not anderstand is the shifting of the filter-window when switching between ctune on and off. I may have something wrong im my setup. Here to show it in DIGU with 3KHz Filter and 4X zoom:
W2SDR wrote:I wish that the AM to SSB TX profiles would change with mode as well, just like in 3.4.9 of protocol 1. This is because most of us use different TX profiles between SSB and AM.
Helmut wrote:Richie, you are right, it is only on 4X Zoom, if I go to 2X it does not jump ! And I am always in DUP mode.
So will work with CTUN off for the moment, that´s no problem - only wanted to make it visible here.
Thank you so much for your changes, it is terrific to see how Thetis improves !
Regards,
Helmut dl9eri/oe9eri
ramdor wrote:W2SDR wrote:I wish that the AM to SSB TX profiles would change with mode as well, just like in 3.4.9 of protocol 1. This is because most of us use different TX profiles between SSB and AM.
at the moment, lsb, usb, am, sam, etc are one and the same. digu/digl and fm have their own tx profile store. I will add AM when I get a mo.
nico wrote: Is there a page we can crowdfund and donate to you?
Nicholas
Tony EI7BMB wrote:Great ideanico wrote: Is there a page we can crowdfund and donate to you?
Nicholas
vk1hx wrote:I think I missed something somewhere.
The latest c3 update doesn't seemed to hold the application size when you resize it. On relaunch its back to the previous sizing.
