Can someone explain the setup under calibration tab for the Level Cal ?
Is there a auto setup using start button ?
Does this set the base noise level of the receiver when terminated ?
If not how do you use the Level Cal to check the 7000DLE ?
Cecil/W4CM
Level Cal adjustment for 7000DLE
Re: Level Cal adjustment for 7000DLE
This changes the power measurement calibration of the radio.
It has to be done using a calibrated signal source.
You attach the signal source to the radio with it programmed to a given frequency and output power level. You tune that signal, then put in the frequency and the level of the calibration signal, then press start.
If you don't have a calibrated signal source you really can't use this feature properly.
I've never heard of anyone who has actually done this finding that their radio was more than 1 or 2dB off from being "perfect". Of course most of those people were using hobby equipment like the Elecraft XG3. Such equipment might very well be off by 1 or 2dB itself, since they are not precision lab instruments and not subject to periodic NIST traceable calibration like a lot of professional lab equipment is.
Been following the noise measurement discussion on emails. Trying to get the -134dBm level but I think I hit the Cal level start without a ref and changed the setup. I tried a previous saved database and got closer.
How do I start all over and erase the present Thetis 2.6.7 download ?
w-u-2-o wrote:I've never heard of anyone who has actually done this finding that their radio was more than 1 or 2dB off from being "perfect".
I actually calibrate my 7000DLE. I have a R&S SMG 801.0001.43
w4cm wrote:Been following the noise measurement discussion on emails. Trying to get the -134dBm level but I think I hit the Cal level start without a ref and changed the setup. I tried a previous saved database and got closer.
If your saved database is before you did the level cal then you don't need to start over. Otherwise just push the reset database button.
Last weekend I successflly moved from P1 to P2 (Thetis 2.6.8 c5) with my 7000 DLE. Checking my S- meter readings with my XG3 I noticed that they were 8 dB too low. So I tried to perform a level calibration on 30m like I did "in the old world" (P1) with PSDRmRX. But I was only able to change the frequency in 1 MHz Steps and the level in 10dB steps. This was different with PSDRmRX.
My question: is this not possible (frequency in kHz and level in single dBm) or did I overlook something?
Volker
DL4ZBG
Volker
DL4ZBG
The spinners do only move in those increments, but you can type the exact value that you want into the box. I just level calibrated my setup using a NanoVNA and some attenuators to put it at exactly -73dBm. Mine was reporting -79 before calibration.
I tried this of course. Yesterday I was not able to edit these values. The edit window background became blue.....
Restarting Thetis 2day and it worked this time. Now the S- meter readings are correct.
Very funny.
TNX
Very funny.
TNX
