Page 18 of 59
Posted: Wed Jul 21, 2021 8:39 pm
21d6b updated
Couple of fixes, see the notes. Please let me know how this goes.
Posted: Wed Jul 21, 2021 8:45 pm
Just as a heads up because I am sure it will be raised at some point. I will be be adding an option that will prevent a slot from being updated, if the current spot frequency etc you are leaving is already in the stack somewhere.
Posted: Thu Jul 22, 2021 2:53 am
there was a quick update to d6, the latest is now 21d6b. A fix for 6m not having the 6m offset removed. Thanks to Todd who reported it.
Posted: Thu Jul 22, 2021 7:13 am
by K0MO
21d6b
"fix: cat/midi band up/down control & collapsed mode band control should now have returned"
Fixed! It's working again. Thanks, Richie!
Manny
Posted: Thu Jul 22, 2021 10:10 am
by PD3LK
Hi, some band-border issues. Maybe these where already there but i just noticed them today.
- i tried to add 198 kHz (BBC) into the LW/MW bandstack but everything below 200 kHz jumps wrongly to the 160m band.
LW = 148.5 - 283.5 kHz
- every frequency between 4 Mhz (end of 80m) and 5.1Mhz is wrongly seen as 61m BC band
61m band (60m) = 4.750 - 5.060 kHz
- 60m amateur band is skipped when vfo tuning (band button doesn't lit up)
There's possibly more. I think these borders are hardcoded in the software but it would be better if users can adjust them in the future. Also to adjust them to there own region. (I.e. overhere 80m stops at 3.8 khz not 4 kHz).
r/Leon
Posted: Thu Jul 22, 2021 10:25 am
by I2NOY
Hi, I checked yesterday d4 and attenuators (0, -10, -20 and -30 dB) act differently on S-meter, FFT and waterfall, from RX1 and RX2.
This afternoon I will try with 21D6b
Posted: Thu Jul 22, 2021 11:43 am
[brain fart] ... scrap this
Helmut wrote:Richie, this Custom AGC store-failure came back again in 21d6b:
2.) With CW when you want to start Thetis with the custom-AGC ( so that you are full QSK and the RX is full open after a -dah- in TX - this settings are not stored when ending Thetis - there is a work around - after starting Thetis with AGC custom set - once switch to -fast- and back to -custom- and the RX is full open again.
Mni tnx !
added to the list . Not sure it got fixed yet. (replied to wrong msg, edited)
Posted: Thu Jul 22, 2021 11:51 am
PD3LK wrote:Hi, some band-border issues. Maybe these where already there but i just noticed them today.
[cut]
r/Leon
Hey Leon,
Below are the entries that the Netherlands will be using. It will eventually all be moving to an xml file, or overridden by one.
EDIT: it looks like 0.198 will get put into 160m band if using extended. That is the way it worked previously. Perhaps not what should happen
- n1.jpg (77.51 KiB) Viewed 8865 times
- n2.jpg (143.13 KiB) Viewed 8865 times
Posted: Thu Jul 22, 2021 12:09 pm
and as a follow up, this is when the extended option is turned on in settings. Note, that when fitting a frequency to band it runs down these lists from top to bottom, and takes the first that fits. It used to be a massive If/else statement, some 6500 lines !!!!! It was impossible to change/administer anything in there.
- ex.jpg (202.29 KiB) Viewed 8860 times
Posted: Thu Jul 22, 2021 12:13 pm
I2NOY wrote:Hi, I checked yesterday d4 and attenuators (0, -10, -20 and -30 dB) act differently on S-meter, FFT and waterfall, from RX1 and RX2.
yeah just ignore anything but the latest. All that was stripped out until I get a moment to re-work through.
Posted: Thu Jul 22, 2021 1:36 pm
Running 21d6b on a 7000DLE black case, Protocol 2, Windows 10
When I'm running dual receivers (VFO's synced) the RX2 Display Settings screen doesn't correlate to the band I'm operating in. The pic below was taken while I was operating on 80 meters but the band referenced in the RX2 Display Settings screen is "General" (BCAM). Changing bands in the session doesn't change the band referenced in the RX2 Display Settings screen.
- Capture.PNG (175.19 KiB) Viewed 8821 times
Posted: Thu Jul 22, 2021 2:08 pm
by NC3Z
K1LSB wrote:When I'm running dual receivers (VFO's synced) the RX2 Display Settings screen doesn't correlate to the band I'm operating in.
I had noticed the same thing here last night, but didn't bother to report it as I had not regressed to earlier versions to see when it changed. But had not caused any issues yet, or wasn't yet convinced it was an issue.
Posted: Thu Jul 22, 2021 2:21 pm
Thanks Mark, typeo (copy paste problem) in there. Will sort it this evening. Just had a quick look.
Posted: Thu Jul 22, 2021 2:26 pm
by w4cm
I loaded 21d6b but I do not see the small "b" in the header.
Did I really not load it ?
Posted: Thu Jul 22, 2021 2:32 pm
w4cm wrote:I loaded 21d6b but I do not see the small "b" in the header.
yes i forgot to put it up there, and was not up for redoing it. The zip name will be correct.
Posted: Thu Jul 22, 2021 2:45 pm
by w4cm
Posted: Thu Jul 22, 2021 3:54 pm
by PD3LK
ramdor wrote:and as a follow up, this is when the extended option is turned on in settings. Note, that when fitting a frequency to band it runs down these lists from top to bottom, and takes the first that fits. It used to be a massive If/else statement, some 6500 lines !!!!! It was impossible to change/administer anything in there.
Many thanks for your time and reply Richie.
I see what you mean, i have Extended off now: everything < 200 kHz is within the bandstack part "GEN" but there's not a GEN band button to lit up.
A change in the future seems logical, seperate bandstacks & bandbuttons for LW and MW with there correct boundaries but this doesn't have prio for now so i'll set a reminder for this under "wishes". r/Leon
Posted: Thu Jul 22, 2021 3:59 pm
PD3LK wrote:ramdor wrote:and as a follow up, this is when the extended option is turned on in settings. Note, that when fitting a frequency to band it runs down these lists from top to bottom, and takes the first that fits. It used to be a massive If/else statement, some 6500 lines !!!!! It was impossible to change/administer anything in there.
yeah it is moving towards that slowly. I am planning on making a new band grid, that can be setup with your own filters, defaulted to some norm of course. Lack of time this week, but should be fine next week to spend some decent time on things.
I have just been reworking the code that decides on band as it had some things I didn't like too much that I had to do last week sometime to get around an issue. Also, the display on the RX1/RX2 in setup to show what band grid data is being used has been reworked.
Posted: Thu Jul 22, 2021 4:11 pm
by oe3ide
I noticed yesterday:
Selecting "SWL" and then "41m"...tuning to a AM-station @7250khz.. the band-selector changes back to "HF"...So its not possible to add this AM-station in the 41m shortwave band to the "SWL 41m" bandstack... the entry is added to the "40m HF" stack.
Both is "correct". 7250 is in the region 2 40m-band and in the 41m shortwave band.
Not a big deal.. just to have mentioned it.
Posted: Thu Jul 22, 2021 4:31 pm
yes Ernst. Not sure what to do about this yet, as it is like that in old Thetis. I just started 2_8_11 base, and tested Sweden as I had seen that there were overlaps. Sure enough, clicking on the SWL 49m takes me through to 60m HF.
Something has to give way if a frequency is in two bands. As frequency changes the code is run to determine current band based off that frequency. It takes the top one off a list of possible bands, the list is ordered to give ham bands priority. If the band changes, so does the filter/stack window.
Could you let me know what region is configured & if you are using extended option.
Edit: of course, preventing any overlap in the band extents would solve it....but....
Cheers,
Posted: Thu Jul 22, 2021 4:39 pm
by oe3ide
ramdor wrote:yes Ernst. Not sure what to do about this yet, as it is like that in old Thetis. I just started 2_8_11 base, and tested Sweden as I had seen that there were overlaps. Sure enough, clicking on the SWL 49m takes me through to 60m HF.
Cheers,
Yes, a difficult situation. I have selected Region 1 with extended ticked.
Maybe an additional flag in your bandstack-table? If user selects "SWL", this could be stored in a variable (and cleared after the user selects another area (HF, VHF,...) ... like a additional filter in your table.
Posted: Thu Jul 22, 2021 4:41 pm
Actually a correction there...
They work through like this, the first band that is an ok match is used.
Any country with Extended checked on
lmf range
wwv spot freqs
swl ranges
ham ranges
US
ham ranges
wwv spots freqs
lmf range
swl ranges
All other countries (including region 1/2/3 setting)
ham ranges
wwv spot freqs
lmf range
swl ranges
This order defines everything that happens inside Thetis in terms of band selection. It is how it used to be in over 6500 lines of if statements.
Posted: Thu Jul 22, 2021 4:48 pm
oe3ide wrote:Yes, a difficult situation. I have selected Region 1 with extended ticked.
Yep, extended is a total over-ride, it builds a new list that is in the order above. Incredibly, looking at it, I think if you run R1/2/3 without extended bad things will happen, in that no band edges are defined for ham bands
Posted: Thu Jul 22, 2021 5:40 pm
In extended mode, if you notice the lists are used in a different order. The extended 41m low cut is defined 7.3mhz however, so it would have missed your 7.250 station. Perhaps it should be moved? The SWL's are 'hit' test first in extended mode, and then a 40m ham entry wraps from 7meg to 8.7. Extended is like a country in its own right, it doesn't extend other countries.
Posted: Thu Jul 22, 2021 5:54 pm
by oe3ide
A good question... but who knows the sideeffects, if the low cut is moved to 7.2.... really tricky
For me its not a big deal, I am not really a big swl listener, just noticed it accidental
Posted: Thu Jul 22, 2021 5:58 pm
by oe3ide
2) VAC resampler initialisation issues (Scott)
I noticed that I can clear the issue by just disabling/enabling VAC1. This worked 100% so far.. fyi
Posted: Thu Jul 22, 2021 6:23 pm
I have put up all the band related stuff on a sheet for now. Perhaps a look at that lot to see what needs changing/swapping. Also keep in mind that this is the same way that old band decision was made, but instead 6000+ lines of If/Else.
https://bit.ly/3BwESZ1Remember, Thetits works down the list for each region, and will return the band that first surrounds the frequency in question.
Posted: Fri Jul 23, 2021 10:14 am
by DL2XY
The phase margin of the FLL control loop is supercritical, depending on buffersize and samplerate setting.
I had to adjust the proportional gain and slew rate in source.
The patch below give me stable conditions for my setting (48ksmp,10ms,512bytes).
This involves a slightly higher settling time (about 1 to 2 Min) but is perfect stable after one 10% overshoot.
For a perfect solution these values would have to be calculated at runtime according to setting.
73 Walter
file: wdsp/rmatch.c Line 501void* create_rmatchV(int in_size, int out_size, int nom_inrate, int nom_outrate, int ringsize)
return (void*)create_rmatch (
1, // run
0, // input buffer, stuffed in other calls
0, // output buffer, stuffed in other calls
in_size, // input buffer size (complex samples)
out_size, // output buffer size (complex samples)
nom_inrate, // nominal input sample-rate
nom_outrate, // nominal output sample-rate
0.0, // fc_high (0.0 -> automatic)
-1.0, // fc_low (-1.0 -> no low cutoff)
1.0, // gain
3.0, // startup delay (seconds)
1, // automatic ring-size [not implemented yet]
ringsize, // ringsize
1024, // R, coefficient density
1.0, // initial variable ratio
4096, // feed-forward moving average min size
262144, // feed-forward moving average max size - POWER OF TWO!
0.01, // feed-forward exponential smoothing
4096, // proportional feedback min moving av ringsize
16384, // proportional feedback max moving av ringsize - POWER OF TWO!
1.0e-06, // (4e-6) // proportional feedback gain
1, // linearly interpolate cvar by sample
0.001 // (0.003) // slew time (seconds)
Posted: Fri Jul 23, 2021 11:31 am
by DL2XY
Just some Bugs:
Thetis v2.8.11 21d6b,ANAN100, WIN7 X64
- PSform Button Advance: Black Text on black background.
- Setupform/Display/RX2: Band indication is fixed on random Band.
Settings are applied global to all bands.
- Console:
Command line option "-datapath:" is broken. If used target path is ignored but "C:\" is used instead.
This leads to database corruption if multiple instances are installed.
