Page 1 of 2
Thetis 2.7.0
Posted: Thu Feb 06, 2020 1:22 pm
by DH1KLM
FYI, Thetis 2.7.0 sources out now.
https://github.com/w5wc/Thetis-2.7.0Compiled it yesterday and did a short test.
Look's OK so far, but have to play around a bit more.
Re: Thetis 2.7.0
Posted: Fri Feb 07, 2020 6:50 pm
by DL8LAQ
Hi Sigi,
I would like to test your compiled files. I don't know how to compile the sources on my windows pc, maybe we can talk by phone oder teamspeak.
Re: Thetis 2.7.0
Posted: Sun Feb 09, 2020 12:46 pm
by DL8LAQ
Hi Sigi,
I did install Visual Studio 2019 yesterday and it seems to works. Just tested the self-compiled 2.6.9 and 2.7.0.
I just tried to TX with my 2-m-band-xvtr, but failed due to not working ptt control. The xvtr ptt is connected to the rear panel rca jack on my ANAN-7000.
I switched back to 2.6.9c3 by Richie.
Re: Thetis 2.7.0
Posted: Sun Feb 09, 2020 12:56 pm
by 4z1ao
Compiled it too.
Played a bit with the Release version. Looks good so far.
73 Isaac 4Z1AO
Re: Thetis 2.7.0
Posted: Sun Feb 09, 2020 1:02 pm
by DL8LAQ
4z1ao wrote:Compiled it too.
Hi Isaac,
can you please try to setup for a 2-m-xvtr and check the ptt output on your radio?
Re: Thetis 2.7.0
Posted: Sun Feb 09, 2020 6:53 pm
by NJ2US
Are there any release notes for 2.7.0? Can anyone summarize the difference between this version and 2.6.9?
Jeff NJ2US
Re: Thetis 2.7.0
Posted: Mon Feb 10, 2020 11:42 am
by DH1KLM
DL8LAQ wrote:I switched back to 2.6.9c3 by Richie.
I recommend to ask Richie about the changes.
Maybe he could point you in the right direction.
too bad that Richies source files are not visible, otherwise you could search for the differences in the XVTR control yourself. Today I try to connect the Alex interface and report back what the XVTR PTT does for me.
Re: Thetis 2.7.0
Posted: Mon Feb 10, 2020 11:55 am
AFAIK, Richie is taking a break from coding. That means any changes are most likely from Doug and Laurence and associated with the Andromeda project.
Re: Thetis 2.7.0
Posted: Mon Feb 10, 2020 12:02 pm
by W4WMT
jeffreydoran wrote:Are there any release notes for 2.7.0? Can anyone summarize the difference between this version and 2.6.9?
Jeff NJ2US
It's kind of difficult to know, because 2.7.0 has forked off into a completely new git repository, and so we can't do a simple diff to see all the changes.
I just did a file compare in WinMerge between 2.6.9 and 2.7.0 in W5WC's GitHub. All the low level stuff is exactly the same, ie zero changes in WDSP and The ChannelMaster. Many changes were done in the Console and Setup classes. The Console is a scary and confusing place that dates all the way back to the SDR-1000 days at Flex, so it's hard for me to understand what all the changed were. My sense, after scanning quickly through all the changes, is there was a lot of code cleanup, housekeeping, and some modest refactoring in Console and Setup.
Re: Thetis 2.7.0
Posted: Mon Feb 10, 2020 4:53 pm
by 4z1ao
DL8LAQ wrote: Hi Isaac,
I'll try and let you know.
Re: Thetis 2.7.0
Posted: Mon Feb 10, 2020 5:25 pm
by DL8LAQ
4z1ao wrote:DL8LAQ wrote:can you please try to setup for a 2-m-xvtr and check the ptt output on your radio?
I think it's ok now with f/w Orion_MkII_NP_v2.0b! Now I can use the self-compiled 2.7.0. The footswitch is working in CW and the PTT out is active, that means the PA PTT or the XVTR is controlled by footswitch! That is what I missed for long time!!!!
By the way, the PTT by space bar seems to not work now - yes, I enabled MOX by space bar - but that is no problem since the footswitch is available in any mode.
Thank you guys for fixing this
Re: Thetis 2.7.0
Posted: Mon Feb 10, 2020 7:34 pm
by DH1KLM
Hello Norbert,
good to hear it is working now.
For spacebar PTT have a look at the pic.
- 1.PNG (29.29 KiB) Viewed 20674 times
- 2.PNG (15.23 KiB) Viewed 20674 times
Re: Thetis 2.7.0
Posted: Wed Feb 12, 2020 6:05 pm
by DL8LAQ
DH1KLM wrote:Hello Norbert,
Hi Sigi,
that is the solution. Thank you!
Enable shortcuts was not ticked.
Re: Thetis 2.7.0
Posted: Sat Feb 15, 2020 7:10 pm
by GW0DQW
Space bar working Norbert , thank you very much .
Chris
GW0DQW
Re: Thetis 2.7.0
Posted: Sun Feb 16, 2020 1:29 pm
by dj1yr
have compiled thetis 2.7.0, if you want to test, please ...
https://www.file-upload.net/download-13 ... 0.zip.html
Re: Thetis 2.7.0
Posted: Sun Feb 16, 2020 2:01 pm
by Tony EI7BMB
Thanks but could not get this working, radio would not switch on . back to 2.6.9
Re: Thetis 2.7.0
Posted: Sun Feb 16, 2020 3:48 pm
by dj1yr
Did you choose the right radio?
Re: Thetis 2.7.0
Posted: Sun Feb 16, 2020 5:02 pm
by Tony EI7BMB
I presume so as it updated existing database.
Re: Thetis 2.7.0
Posted: Sun Feb 16, 2020 8:02 pm
by DH1KLM
I had the same experience when updating an existing database.
Obviously the radio model is not updated in Setup> General> H / W Select.
I noticed this behavior even after importing an older database. The radio was then set to HPSDR instead of Hermes.
But I think that most of the other settings were adopted, at least I could not find any other differences.
Re: Thetis 2.7.0
Posted: Sun Feb 16, 2020 11:31 pm
by dj1yr
It was the same with me
Re: Thetis 2.7.0
Posted: Mon Feb 17, 2020 9:45 am
by Tony EI7BMB
Thanks guys you were right, the correct radio was not selected . Seems to be working on RX so far.
Re: Thetis 2.7.0
Posted: Fri Feb 21, 2020 9:15 am
by Tony EI7BMB
2.7.0 does not seem to remember the last TX mode on startup , anyone else seeing this ?
Re: Thetis 2.7.0
Posted: Fri Feb 21, 2020 3:54 pm
by rbduck
I'm having no issues with Thetis 2.7.0 remembering the TX mode on startup
Re: Thetis 2.7.0
Posted: Fri Feb 21, 2020 6:02 pm
by DK1WP
After the first start of 2.7.0 under General -> H/W Select the correct transceiver was not taken over.
Also the audio profile (Transmit Filter as well as CFC settings) had to be adjusted.
All other settings like PA Settings, Display, CAT were taken over from 2.6.9.
Re: Thetis 2.7.0
Posted: Fri Feb 21, 2020 6:15 pm
by Tony EI7BMB
Yes the database upgrade did not capture the mode so has to be set correctly and saved again under the correct TX profile.
Edit: Tested again and the program resets every time to LSB when profile was set to DIGU
Re: Thetis 2.7.0
Posted: Fri Feb 21, 2020 11:47 pm
by rbduck
In this case yes. The first time I started 2.7.0 I had to go through and correct many settings that did not come over from 2.6.9. After that I had no issues.
Re: Thetis 2.7.0
Posted: Sat Feb 22, 2020 12:03 pm
by Tony EI7BMB
Yep definitely an issue here , no matter what I do it goes back to LSB on startup unless I'm missing something obvious. Not a big deal either way
Re: Thetis 2.7.0
Posted: Mon Feb 24, 2020 9:21 pm
by dalemitchell
Where can i download Thetis 2.7.0 $
Re: Thetis 2.7.0
Posted: Tue Feb 25, 2020 1:19 am
by dj1yr
Re: Thetis 2.7.0
Posted: Tue Feb 25, 2020 12:02 pm
by dalemitchell
Dale
