TX Signal Meter jumps to Fwd PWR on transmit
Postby oe3ide » Sat May 22, 2021 2:44 pm
see video. Immediatly after TX, the signal meter jumps to "fwd pwr", regardless the previous selected meter...
https://www.oe3ide.com/wordp/wp-content ... _meter.mp4
Even I select SWR in the transmit-tune section as tx-meter, on tuning the tx-meter jumps again to fwd pwr.
Any ideas whats wrong here?
Thanks & 73s
Ernst
Re: TX Signal Meter jumps to Fwd PWR on transmit
Postby oe3ide » Sat May 22, 2021 2:59 pm
Postby oe3ide » Sun May 23, 2021 7:51 am
Ok, a complete windows-restart solved the problem. I had this effect several times.
73 de Ernst
Postby oe3ide » Mon May 24, 2021 2:00 pm
For the records: TMate2CatConsole was the trouble-maker. Not at the beginning, but over some run-time, the cat-connection from Thetis to TMate2CatConsole "resets" the TX-meter to "Fwd pwr" on each TX (mox, ptt).
LA2NI
Postby LA2NI » Tue May 25, 2021 4:19 pm
Hi Ernst.
I do not know what Tmate 2 Console is but I have this problem all the time. I can set it to Fwd/SWR but it jumps to Fwd after the next PTT ore tune. I use Andromeda Prototype and latest version of Thetis. But I have seen this also when using my Hermes/Apollo and Thetis. I have tried to save the TX profile several timed but that does not help.
73, LA2NI, Kjell
Postby oe3ide » Tue May 25, 2021 5:03 pm
Hi Kjel,
which software do you have connected to the virtual cat-ports in Thetis? Maybe another software is also making garbage.
LA2NI
Postby LA2NI » Tue May 25, 2021 9:22 pm
Hi Ernst.
The Andromeda Front Panel with an Arduino Nano Every is connected to one CAT port and the Aries ATU with an Arduino 33iot to another. But as I say this also happens when Hermes/Apollo is used without anything connected to the CAT ports.
73, Kjell
