Postby w-u-2-o » Mon Apr 18, 2022 3:54 pm
EA1DAV wrote:May be I am wrong, but this measuremet is dB and not dBm.
Agree with this. Please change to dB.
[Not sure what PBNP is.
That is "passband noise power". It is a real-time estimate of passband noise power based on the power measured in the panadapter RBW (resolution bandwidth) and as displayed by the noise line. This power is scaled/normalized to a 1Hz bandwidth and shown as NPSD--noise power spectral density. That noise power is again scaled/normalized to the passband bandwidth to obtain PBNP.
While PNBP is technically only an estimate, it's pretty accurate. You can adjust it further by going to a quiet part of the band, switching the S-meter to show dBm (Settings > Display > General), then going to Settings > General > Options > Options-2 and adjusting Noise Floor Shift. It shouldn't be more than a couple of dB off.
With PNBP being estimated, that gets you a real-time PBSNR: passband signal-to-noise ratio. SNR is, arguably, a much more useful metric when judging signal power and quality. Not the norm in the CW/phone realm yet, but very familiar to the digi mode folks.
If your PBSNR reading is not updating often enough for you, its update rate, and the update rate of all the rest of the values on the InfoBar (the strip just below the spectral display) is controlled by Setup > Display > General: Refresh Rates CPU Meter. I have mine set to 250ms and that seems to work quite well. If you want to report SNR in S-units, just take the PBSNR value and divide by 6 in your head :)
These new metrics are wonderful additions, thank you Richie!
Postby ramdor » Mon Apr 18, 2022 4:09 pm
w-u-2-o wrote:If you want to report SNR in S-units, just take the PBSNR value and divide by 6 in your head :)
or use the option to do it for you, again in options 2
still trying to find this atten bug in the spaghetti
KA5KKT
Postby KA5KKT » Mon Apr 18, 2022 4:24 pm
ramdor wrote:@Dick - KA5KKT
1) reboot
2) uninstall
3) check folders
C:\Program Files\OpenHPSDR\Thetis
or
C:\Program Files (x86)\OpenHPSDR\Thetis
have no lingering dlls
4) reinstall
5) run up thetis and leave it start
If it is stuck again, make sure there are no popup windows behind the splash screen, by hovering over Thetis taskbar icon to see if any other windows are there
if nothing and still stuck, check task manager for Thetis.exe. If in list end task
check for Errorlog.txt in C:\Users\<user>\AppData\Roaming\OpenHPSDR\Thetis-x64 or C:\Users\Richie\AppData\Roaming\OpenHPSDR\Thetis
I had tried as you suggested a time or two before my OP. After your reply, I tried again. It worked...up to the point I imported my latest Settings Database. At that point a restart of Thetis yielded the same as outlined previously. I cleaned it all up again, reinstalled and on this occasion imported a bit earlier database. All seems to be working fine now. I must assume the later Settings Database had some sort of corruption in it.
Thank you kindly for keeping me after it,
Dick - KA5KKT
Postby ramdor » Mon Apr 18, 2022 4:28 pm
Dick - KA5KKT
can you email the db that goes wrong? email over on qrz, cheers.
Postby w-u-2-o » Mon Apr 18, 2022 5:02 pm
Ha! I was not quite yet on the latest beta. But I am now :D
On that note, playing with the new "Adjust Min to Noise Floor" setting, as you know at lower zoom settings (large panadapter bandwidths) there can be a significant tilt or variation in the average noise floor. In the spirit of Yet Another Option, would it be possible to get an offset adjustment on this setting so that there could be some leeway for this? I think most people would be OK with a little taller "grass" growing at the bottom of the panadapter such that small signals didn't go missing in other places--thanks!
Postby K1LSB » Mon Apr 18, 2022 5:16 pm
w-u-2-o wrote:.
I have the same mindset, right now I do it manually by vertically dragging the spectrum display so as to just show a little grass at the bottom.
va7qi
Postby va7qi » Mon Apr 18, 2022 5:29 pm
After installing rev 4 Thetis does not seem to connect to the radio properly. No firmware version is shown and the radio does not seem to be alive. The frequency windows and power button light up.
I was previously using the latest release.
73 de va7qi, ....Erik.
Postby ramdor » Mon Apr 18, 2022 5:35 pm
va7qi wrote:Hi Richie,
perhaps didn't uninstall the old version? Uninstall, check the install folder for any old dlls (C:\Program Files\OpenHPSDR\Thetis or C:\Program Files (x86)\OpenHPSDR\Thetis), and re-install.
I may give up on this WIX installer for these repeated updates to an existing install.
DL8LAQ
Postby DL8LAQ » Mon Apr 18, 2022 5:50 pm
ramdor wrote:can you send me your db? enjoy the tasting :)
Done! Sent to qrz.com
Postby ramdor » Mon Apr 18, 2022 5:52 pm
Done! Sent to -----
will take a look later this evening, still working through the att problem. Not found the cause yet.
Postby ramdor » Mon Apr 18, 2022 6:01 pm
Done! Sent to -------
the reason I tell people to get my email from qrz is that it is somewhat hidden behind a login process
I could post it to public forum here, but I don't.
Thanks for that :evil:
va7qi
Postby va7qi » Mon Apr 18, 2022 6:03 pm
Uninstall/re-install worked. TNX de va7qi, ....Erik.
DL8LAQ
Postby DL8LAQ » Mon Apr 18, 2022 6:26 pm
Correction done!
ULTIMAX
Postby ULTIMAX » Mon Apr 18, 2022 6:41 pm
I think this was stated as been notice not sure, I install the new beta test and I notice that the ATT which I always keep in -20db , it was on 0 as default and after engaging it back to -20db like always , the receiver got way too quiet, even max out the RF gain , is way too low
I went to 80Meters and is even worst than the higher bands, I'm force to keep the 0, or -10db in the lower bands and the RF gain max out to be able to hear well, I still can hear but is so low is weird.
Albert
N3YV
73'
Postby ramdor » Mon Apr 18, 2022 6:48 pm
yes, there are a couple of issues that I am in the middle of looking at.
eta.. a couple of hours :(
Postby ramdor » Mon Apr 18, 2022 9:04 pm
ok, that took far too long. When the code takes different paths depending if the attenuation string is -50dB or -50db you know that it is going to be a struggle. Hopefully that will sort out that attenuation problem. It seems to be working ok on my 7000.
Anyway, please try 2.9.0.4 and like before, uninstall if you are running 2.9.0.4 or 2.9.0 rev4, before re-installing.
https://github.com/ramdor/Thetis-2.9.0/ ... .9.0.4-pre
add: offset to the noise floor GridMin option
fix: rx2 GridMin's will only be updated if RX2 is in use
DL8LAQ
Postby DL8LAQ » Mon Apr 18, 2022 9:15 pm
ramdor wrote:ok, that took far too long. When the code takes different paths depending if the attenuation string is -50dB or -50db you know that it is going to be a struggle. Hopefully that will sort out that attenuation problem. It seems to be working ok on my 7000.
The ATT bug using ADC0 for RX1 and RX2 seems to be fixed.
Thank you, Richie! Good night...
Postby w-u-2-o » Mon Apr 18, 2022 9:15 pm
Richie--would it please be possible to increment the "x" in 2.9.0.x? And to show the entire version number in the title bar? Configuration management is becoming difficult without this.
Postby ramdor » Mon Apr 18, 2022 9:24 pm
w-u-2-o wrote:Richie--would it please be possible to increment the "x" in 2.9.0.x? And to show the entire version number in the title bar? Configuration management is becoming difficult without this.
I cant include the the changing number in the true version number on the left easily, otherwise a database update will happen every new revision. If we want to change the dB version, then it would become 2.9.1. I have put the 4 from 2.9.0.4 on the end of rev, so rev4. However, as it is a pre-release (as per the tag in github) there may be many .4's before a full release of .4.
I will have a think about it, and probably recode the version detection for dB update.
Postby w-u-2-o » Mon Apr 18, 2022 9:31 pm
Ouch! Yes, it would be better if the fourth digit did not kick off a DB reset, while the third one did. That would work fine.
ULTIMAX
Postby ULTIMAX » Mon Apr 18, 2022 10:02 pm
Richie, I click that link for the try out 4-pre and it takes me no where
Al
73'
Postby ramdor » Mon Apr 18, 2022 10:09 pm
Al
73'
ahah, wrong link... https://github.com/ramdor/Thetis-2.9.0/ ... .9.0.4-pre
W4WMT
Postby W4WMT » Mon Apr 18, 2022 10:57 pm
ramdor wrote:I will have a think about it, and probably recode the version detection for dB update.
What about a scheme where the 4th segment (2.9.0.x) increments during a string of beta releases. But then, when it goes to the TAPR GitHub repo for release, the 4th segment is dropped and we increment the 3rd segment (e.g. 2.9.1)?
73, Bryan W4WMT
Postby ramdor » Mon Apr 18, 2022 11:25 pm
That is what we are doing as we do not show the revision number in the title bar.
2.9.0 was the original release
2.9.0.1 can overwrite 2.9.0
2.9.0.4 can overwrite 2.9.0.1
however, when I am continually working through issues in 2.9.0.4 as it is 'pre-release' then an update will not overwrite 2.9.0.4 automagically.
I do not really want to create potentially hundreds of incrementing revisions. There will be a message eventually, and post 1 will be updated with 2.9.0.4, and perhaps TAPR at the same time.
W4WMT
Postby W4WMT » Mon Apr 18, 2022 11:54 pm
ramdor wrote:That is what we are doing as we do not show the revision number in the title bar.
Right, but what I was thinking is, e.g. last week when 2.9.0.3 went up to github.com/tapr for "official" maintenance release, the 3rd segment would increment to 2.9.1. Then you could start off with subsequent beta drops as 2.9.1.x. FWIW (which is probably nothing :-) )
Postby ramdor » Tue Apr 19, 2022 12:03 am
@everyone,
If you are using 2.9.0.4 (rev4) (pre-release), please let me know what radio model you are using with it, and the protocol.
Cheers.
Postby w-u-2-o » Tue Apr 19, 2022 1:00 am
8000 & P2
NJ2US
Postby NJ2US » Tue Apr 19, 2022 1:10 am
7000, P2
Win 10 i9-10900K 32Gb RAM NVIDEA RTX2060
Jeff NJ2US
Postby K1LSB » Tue Apr 19, 2022 1:22 am
7000 black case, P2
N4QNT
Postby N4QNT » Tue Apr 19, 2022 1:23 am
7000DLE MKII P2- v2.1.18
