Posted: Sun Apr 03, 2022 11:41 pm
2.9.0 Updates - latest 2.9.0.6
A new thread and a new approach.
To move to a new version, please uninstall and then reinstall.
(note: uninstalling using add/remove programs, leaves behind your database and does not remove it)
All modified source, releases and issues are now public on github here : https://github.com/ramdor/Thetis-2.9.0
Current known issues are here : https://github.com/ramdor/Thetis-2.9.0/issues. Either report new ones here, or over there.
Old Main thread : viewtopic.php?f=9&t=3817
Old Wants/Wishes : viewtopic.php?f=9&t=3861
[2.9.0.6] https://github.com/ramdor/Thetis-2.9.0/ ... g/v2.9.0.6
-fix: rx2 now has display calibration applied in the level calibration code
-fix: zzzb now runs the 0beat if in collapsed view
-fix: fix for crash if Tdrv was being used as one of the two infoBar buttons
-add: reset button added to level calibration
-change: grid follows nf disabled when performing freq cal / level cal, reenabled at end if previously enabled
[2.9.0.5] https://github.com/ramdor/Thetis-2.9.0/ ... g/v2.9.0.5
fix: filter width slider now works with mouse wheel in both directions
fix: filter shift slider now works with mouse wheel in both directions
fix: fixed issue with TCI band change which sends tx_enable (rx's were flipped)
fix: vhf+ and swl buttons were not showing the button groups in compressed view
fix: tx filter lines not being shown on waterfall in rx
fix: .net socket classes would fail (tci/tcpipcat) if radio hardware not found. Caused by incorrect use of WSACleanup in network.c. WSACleanup closes/terminates all sockets for all threads in this process
fix: start state for RX2 meter set to -200dBm, fixes the S9+60 start
fix: RX1 waterfall was not resized in collapsed view when RX2 was turned off in some cases. This could cause missing or 'overlapped' waterfall display
fix: RX1 panafall waterfall not resized correctly when running RX2 and changing back to panafall in RX1
fix: <FW> showing in collapsed view
fix: RX2 was not having its meter or display calibrations set based on radio model on start up. RX1 was, but not RX2
fix: attenuators now apply to the correct ADC's based on DDC config. This needs testing.
add: emulate ExpertSDR3 in TCI settings. Causes 'protocol' TCI output command to use device ExpertSDR3 instead of Thetis
add: emulate SunSDR2Pro in TCI settings. Causes 'device' TCI output command to use device SunSDR2PRO instead of Anan model
add: passband and rbw dBHz display on infoBar page 2
add: IPv4 IP selection dialog for CAT/TCI/N1MM servers
add: option to turn on/off external speakers on 7000/8000 protocol2 radios. Only in setup atm, but will feature on front end at some point
add: new PA profile system WARNING : check your PA settings before use (https://youtu.be/PlkBoOA5rfQ)
add: split_enabled is now sent on TCI initial connect (requirement for RF-Kit amps)
add: new limit system. Right click drag Drive/Tune slider. Use SHIFT + mouse wheel to adjust +- 1
add: new info added to page2 of infoBar (click to cycle pages). NPSD - noise power spectral density, PBNP - estimated passband noise power, PBSNR - estimated passband snr (s-meterAV - PBNP)
add: dBm/Sunit option for infoBar page2 in General-Options-Options2
add: options for noisefloor sensitivity and offset in General-Options-Options2
add: hold shift when clicking VAC1 to set same state to VAC2
change: 192KHz sample rate check made on the PS loop back (Display PS-RX and PS-TX spectra in linearity form). Note this display will always be centred irrespective of DUP state
change: changed layout of CAT tab(s)
change: fixed some terminology for getUserIxx P2 functions in netinterface.c
change: Tune and 2Tone now have new slider options. You can pick Drive, Tune, or fixed for each
change: infoBar Tdrv changed to PanFill
change: ZZDY cat command removed, code was not being used. Previously known as DX. Note: DownwardExpander is NoiseGate in CAT terms
change: bandstack reset or fresh install will add default 60m entries for US region
change: GridMin to NF only adjusts when the NF has settled. Different to 2.9.0.4
[22a] https://github.com/ramdor/Thetis-2.9.0/ ... g/v2.9.0.1
fix: issue in 21k9c with broadcast VFOA/B(FA/FB commands) was causing truncation of digits if frequency ended in 0's
fix: installer now has Windows7 as minimum os (601)
fix: WindowsFirewallHelper.dll included in the installer
change: split delegate only called if split state changes (fixes unnecessary duplication with ZZSW in AI broadcast + general cat)
