Splash disable?
w8du
Splash disable?
Postby w8du » Wed Jul 06, 2022 1:36 pm
I am wondering if there is a way to turn off the Ukraine splash screen. While I am totally in sympathy with the people of Ukraine and have done what I can to support them, I am finding it less than useful to have the initial Ukraine splash screen show up every time I start Thetis. IS there a way to turn that off or at least to have it disappear on its own after it is displayed?
Tnx de Arnie W8DU
Re: Splash disable?
Postby K1LSB » Wed Jul 06, 2022 1:59 pm
Click on the Ukraine flag and it'll disappear.
w8du
Re: Splash disable?
Postby w8du » Wed Jul 06, 2022 2:45 pm
Yes, I know that. I am looking for a way for it either to stop appearing or to disappear by itself without having to click on it.
Tnx de Arnie W8DU
Re: Splash disable?
Postby w-u-2-o » Wed Jul 06, 2022 4:18 pm
There is no way of changing this without modifying the code.
The entire codebase is available for download from Richie's GitHub repository.
w8du
Re: Splash disable?
Postby w8du » Wed Jul 06, 2022 4:43 pm
Thanks Scott. Modifying the codebase to accomplish this is way above my pay grade.
dynamicfusion
Re: Splash disable?
Postby dynamicfusion » Thu Jul 07, 2022 6:47 pm
I will provide a 2.9.0.6 new-compiled thetis.exe executable perhaps tomorrow that removes the ukraine splash. Optional to those who want it.
w8du
Re: Splash disable?
Postby w8du » Thu Jul 07, 2022 8:29 pm
Thank you. I appreciate it and look forward to that release.
73 de Arnie W8DU
dynamicfusion
Re: Splash disable?
Postby dynamicfusion » Fri Jul 08, 2022 1:31 am
https://www.dropbox.com/s/yn7rrvxu3xd1q ... G.zip?dl=0
NO Malware: https://www.virustotal.com/gui/file/2dc ... ?nocache=1
2.9.0.6 version with no flag splash. Toggled a line from true to false.
x64 bit
replace Thetis.exe in C:/Program Files/OpenHPSDR/Thetis
Last edited by dynamicfusion on Fri Jul 08, 2022 10:45 pm, edited 1 time in total.
w8du
Re: Splash disable?
Postby w8du » Fri Jul 08, 2022 12:05 pm
Thank you for this. However, when I tried to download it, I got a popup asking me to install an extension on my Chrome browser (WIndows). Is this extension legit and is it necessary in order to download your file?
Tnx de Arnie W8DU
NC3Z
Re: Splash disable?
Postby NC3Z » Fri Jul 08, 2022 12:11 pm
w8du wrote:when I tried to download it, I got a popup asking me to install an extension on my Chrome browser (WIndows).
Same thing here, tons of pop-ups and attempts to install things, my Windows security balks at it.
Re: Splash disable?
Postby w-u-2-o » Fri Jul 08, 2022 2:42 pm
dynamicfusion wrote:Sourced from github https://github.com/ramdor/Thetis-2.9.0.git 7-7-2022
That's not where you want to grab the source repository from. That is Richie's sandbox and the code there may contain unfinished features, broken features, and other bugs.
The correct place to source the code from is here: https://github.com/ramdor/Thetis-2.9.0/releases
Specifically download either the zip or the the tar.gz source file for 2.9.0.6.
Rebuild that (it's probably all of one line of code difference). Then rather than use some sketchy download site like zippy, simply post here with the revised .exe file in a zip archive as a post attachment. You should be able to attach a zip archive to a post, if not then let me know.
dynamicfusion
Re: Splash disable?
Postby dynamicfusion » Fri Jul 08, 2022 3:48 pm
Attachments are size limited. I cannot post it here.
Re: Splash disable?
Postby w-u-2-o » Fri Jul 08, 2022 9:50 pm
Dropbox? Google Drive?
dynamicfusion
Re: Splash disable?
Postby dynamicfusion » Fri Jul 08, 2022 10:32 pm
x64 bit
w8du
Re: Splash disable?
Postby w8du » Sat Jul 09, 2022 12:05 am
Much better. Thank for uploading to dropbox. I was able to download and save with no problem and no worrisome pop-ups.
Tnx es 73 de Arnie W8DU
Re: Splash disable?
Postby ramdor » Sat Jul 09, 2022 3:07 pm
A shame that these forums host a link to a build like that. I guess some are entitled today, so much so, that either ignoring or single clicking is just too way too much of an afront to one's freedoms or too much effort. Ah well.
Anyway, just to mention, there are a couple of issues with 2.9.0.6 that haven been resolved in the WIP version 2.9.0.7 which has not been released yet. Issues with saving s-meter calibration after a recalibrate, 2tone drives not being restored, importing DB's causing notches to fail and potentially result in a broken db, and a couple of others. Some fixes are up on github, some are not as yet.
I will probably have an interim patch release sometime at the end of this month, just to clear away some of those issues, and a few others that have been reported.
w8du
Re: Splash disable?
Postby w8du » Sat Jul 09, 2022 3:34 pm
Ramdor:
I certainly did not mean to open a can of worms here. I actually was hoping you might respond to my initial inquiry on this thread. I am not that knowledgeable as to how generate a 'build' to be able to do it myselft. Is there something wrong with the build posted my dynamicfusion? I have downloaded it but have not run it yet.
Thanks and 73 de Arnie W8DU
