Receive Signal Overload
Posted: Fri Aug 12, 2022 8:34 pm
by Hadlejeff
I have an odd problem while operating my 7000dle MKII with Thetis. Occasionally when I go from transmit to receive using PTT my receive signal level goes to over 60DB making the receive function unusable. To reset the 7000dle receive function I have toggle the transmit a couple of times and the receiver returns to normal operation. Does anyone have this problem or ideas on how to fix the problem?
Jeff
Re: Receive Signal Overload
Posted: Fri Aug 12, 2022 9:11 pm
by wd6dod
If it does not happen at low to no power suspect RFI.
Bob - wd6dod
Posted: Wed Sep 21, 2022 9:39 am
by Hadlejeff
Thanks Bob, I tried using the tun feature and the problem occurs at high and low power...in fact I can set the drive to 0 and I still have the problem.
Posted: Wed Sep 21, 2022 1:11 pm
by LA2NI
This problem I have had for a very long time with Thetis! To get back to normal I have to toggle Power OFF and ON. I think it has been mentioned several times on the forum.
73, Kjell, LA2NI
