Ring Buffer and PortAudio latency numbers changing
JJ4SDR
Postby JJ4SDR » Sat Aug 27, 2022 3:08 am
Using Thetis v2.9.06 x64 Protocol 2 (2.1.18).
Noticing that the latency figures that I set (Manual boxes all checked) keep changing by themselves after a while of operating the radio. They seem to revert to numbers that I had set a long time ago so my changes alluded to above revert to those "default" numbers. Are these numbers band specific and I need to change them for each?
I assume that I need to Export Database with the new latency numbers or am I missing something? Mainly, I wonder why the manually set numbers keep changing. I wouldn't want to create a new database just to have the latency numbers stay the way I like them.
Best,
Thetis v2.10.4.3 x64
Protocol 2 v2.1.18
A92GE
Re: Ring Buffer and PortAudio latency numbers changing
Postby A92GE » Sat Aug 27, 2022 4:43 am
Those settings are saved in your transmit profile. Unless you save the profile after making adjustments they will revert to previous settings next time you turn off/on the radio or change transmit profiles.
David
A92GE
JJ4SDR
Postby JJ4SDR » Sat Aug 27, 2022 7:18 pm
Hi David!
I see. Thanks very much. Didn't realize these parameters were part of TX Profile, but it certainly is better than having to Export the Database just to have those figures activated.
(OH1HX)
Protocol 2 v2.1.18
