Problem using CFC audio tools in VAC
Posted: Fri Sep 23, 2022 8:09 pm
This probably has a simple answer that I am overlooking. It has been a long time and I want to use the CFC to go through my audio chain and tweak settings. I haven't changed microphones so there should be little change. My problem stems from the fact I cannot get an audio display
with the Panadapter unless I add Drive. There is no audio representation with zero Drive. I know I had no issues with this the first time I did it a couple of years ago with one slight difference. The first time I did it I was feeding the audio from the microphone through the Mic input on front of the transceiver. Now it's done with the microphone input on the PC and completely through VAC.
I really would prefer not to have Drive (rf output) the entire time I'm doing the audio tuning it. What am I missing?
