Thetis v2.9.0x64 with Hermes Prot.1 v3.3 Split is not working.
afilip
Postby afilip » Sat Nov 05, 2022 11:10 pm
Running Thetis under Windows 10.
For some reason Split is not working. I got embarrassed calling DX station working with split.
It turned out that I was calling him on his frequency despite selecting Split and setting VFO B 2 kHz above VFO A frequency.
VFO B turned red TX, TX CW frequency indicator moved to selected frequency and after checking spectrum it turned out that tx frequecy is the same as VFO A frequency.
I had to use XIT to get around that problem however this not that convenient as split.
Am I missing something in Thetis setup?
Adam AC8CE
Re: Thetis v2.9.0x64 with Hermes Prot.1 v3.3 Split is not working.
Postby w-u-2-o » Sun Nov 13, 2022 5:41 pm
I just tried this with Thetis 2.9.0.6, on an 8000 with Protocol 2. I could not duplicate this problem. Split works perfectly for me on CW.
Are you running Thetis 2.9.0.6?
afilip
Postby afilip » Mon Nov 14, 2022 2:29 pm
I was running Thetis v2.9.0x64.
I've uninstalled that version, rebooted my PC and I installed v2.9.0.6.
Thetis 2.9.0.6 is working fine with split. I verified that checking spectrum and listening my CW signal on different receiver.
Thanks for your help.
Adam AC8CE
