Turn off AGC altogether?
Posted: Mon Jan 30, 2023 3:26 am
by W9IP
Dear friends,
Is it possible to turn off AGC altogether in Thetis? I do EME and it is useful to measure signal levels at audio where AGC just gets in the way. Note: I'm not asking about turning off "auto AGC gain mode" (which is so redundant.)
W9IP
Re: Turn off AGC altogether?
Posted: Mon Jan 30, 2023 8:57 am
by DL2XY
W9IP wrote:Dear friends,
W9IP
You want to set the AGC mode to "Fixd"
Posted: Mon Jan 30, 2023 12:08 pm
by W9IP
Do you mean Setup/DSP/AGC-ALC/"Fixed Gain (dB)?
Posted: Mon Jan 30, 2023 12:28 pm
Not Walter but, yes, that's what he means. When you set the AGC to "Fixd" mode in the main UI console drop down control, it turns off AGC and uses a fixed gain that you specify that remains unvarying until you change AGC mode to something automatic.
Posted: Mon Jan 30, 2023 2:39 pm
by W9IP
Perfect, thanks to both of you.
