Hello everyone,
In Thetis it is possible to assign 4 CAT ports. Recently, I connected the TM-2 Elad to my Anan 7000 DLE MKII and it was a test. I missed one CAT port to enable Band Master in my logging program, which needs a port from OmniRig. At Cat I use 2 physical RS232 ports to control the antenna box and the repeater and 2 virtual ports to Turbolog and TM-2.
Maybe someone of you had a similar problem and knows how to solve it?
73's
Slawomir
Thetis and additional CAT
Re: Thetis and additional CAT
Which logger are you running? Most loggers are able to communicate via TCI, some also via TCP/IP Cat.
So the Band Master from your logger needs an extra CAT connection? (in additon to the already OmniRig-connected logger ??)
73 de Ernst
73 de Ernst
Hi Ernst,
I am using German Turbolog 4. I use a pair of ports to connect Turbolog. But Band Master is not an integral part of Turbolog and requires another pair of virtual ports where one is in CAT and the other in OmniRig. There is a tab in Turbolog that launches Band Master. The problem isn't adding port pairs, it's the lack of a fifth CAT in Thetis. I tried using a virtual pore spltter but it didn't work.
Slawomir
Slawomir
The port splitter in VSPE works great. What virtual serial port software are you using?
how I use Eltima Virtual Serial Port Driver Pro. There is a splitter option but the primary port must be a physical port to split to virtual ports. I have two free RS232 ports on the MOXA card but they are not related to Thetis. Is it a big problem to alternatively add an additional fifth CAT to Tehtis?
Slawomir
Slawomir
I've never used the Eltima product.
I use Eterlogic VSPE, https://eterlogic.com/Products.VSPE.html
Create a splitter and connect it to one half of a pair or to an instance of a connector. Thetis goes to either the connector or the other side of the pair.
You might not even need the splitter. Depending on the software, with VSPE sometimes you can get more than one app to connect to the far end of a pair device at the same time.
Hi, I will install Eterlogic. Does it start when you turn on the computer or do you have to turn on start after saved configuration every time you turn on the computer?
And one more thing. If I do a split on a port that is in CAT and supports Anan in the logging program, can I use the added ports in split to TM2 and OmniRig? I have two free RS232 ports in the Moxa card and these ports are visible in the Win 10 device manager. Can I use this port as the main split port or do I need to add a pair of virtual ports in VSPE?
Slawomir
Slawomir
qst wrote:Hi, I will install Eterlogic. Does it start when you turn on the computer or do you have to turn on start after saved configuration every time you turn on the computer?
You can configure it either way. If you install it as a service it will start with Windows. If not, then you have to start it with a startup folder script or manually. It's entirely up to you. I use a script. See the documentation for more information.
Slawomir
There are so many possible configurations I can't begin to answer this question. You will need to experiment.
I have installed Eterlogic VSPE. I want to add 3 ports to one virtual port in the splitter. But in configuration I can only add one. I do not know how to do this.
Slawomir
Slawomir
You can't add three ports to a splitter.
I told you you will have to experiment. You didn't experiment enough.
I just made a pair, COM5 and COM6. Then I made a splitter, COM6 to COM50. I assigned COM5 to Thetis. I assigned COM50 to two different instances of a terminal emulator, call them A and B. I can easily issue commands to Thetis from either A or B.
The only restriction with this configuration is that when A asks for something from Thetis the response will go to both A and B. The same for when B asks for something from Thetis. The software you are using may or may not accommodate that.
Unfortunately, none of the virtual port programs allowed me to split from one virtual port to 2 virtual ports to run Band Master. I guess the only way is to add 5 CAT in Thetis. That would solve my problem. Or maybe someone has another idea?
Slawomir
Slawomir
qst wrote:Unfortunately, none of the virtual port programs allowed me to split from one virtual port to 2 virtual ports to run Band Master. I guess the only way is to add 5 CAT in Thetis. That would solve my problem. Or maybe someone has another idea?
Slawomir
Did you already try the TCP/IP CAT server?
viewtopic.php?f=16&t=4065&p=18275&hilit=tcp%2Fip+cat+server#p18275
73, Hans OE3JRC/PA0Q.
Hans Remeeus (PA0Q/OE3JRC)
https://pa0q.nl
https://pa0q.nl
Hello Hans, nice to meet you again. I don't know how to go about it and will it change anything and allow me to solve my problem?
I will be grateful for help in this matter.
Slawomir SP6DLO
Slawomir SP6DLO
Hans,
I reviewed the information contained in the link. They concern the connection of the N1MM log via TCPIP. I work on Turbolog and it, and it seems that there is no possibility of communication via TCPiP with Anan. I am missing one CAT port to the Band Master that uses OmniRig. My Cats are used for:
1. ATU PA0LL controller (well known to you)
2. Flex PGXL amplifier
3.Turbologist
4. Elad TM2.
I need to check if PGXL can be connected to Anan via TCPIP. If I don't find another solution, I will have to install another login program with integrated Band Master.
Slawomir
3.Turbologist
4. Elad TM2.
Slawomir
qst wrote:Hans,
3.Turbologist
4. Elad TM2.
Slawomir
Hello Slowamir,
good to read that the AutoLLTuner is working fine again.
You may try:
http://k5fr.com/binary/VSPMsetup103.zip
https://k5fr.com/DDUtilV3wiki/index.php/Download
or https://ddutil.software.informer.com/1.8/
73! Hans.
https://pa0q.nl
https://pa0q.nl
Slawomir
Did you follow my example above?
Hi, I solved my problem by installing Eterlogic VSPE. it's the best virtual port program I've tried so far. It can handle several applications from one split port with the same number. I am sending a link to Youtube where everything is shown how to configure it.
Thank you all for your help.
Sławomir
https://www.youtube.com/watch?v=CtlTVJ1gcpo&t=16s
Sławomir
