RX2- receive difference than RX1
Posted: Sun Mar 05, 2023 3:50 pm
today I discovered that I receive stations differently on RX2 than on RX1. In setup, I turned on the same ADC on RX2. On RX2 on the same frequency and antenna as RX1 there is more noise, additional effects like from outer space. It's as if there were no input filters in the RX2. Do you need to change anything else in Thetis setup so that both receivers receive the same? And is the RX2 on while transmitting protected against the transmitter's signal?
Slawomir
Slawomir
