display flicker
Posted: Thu Mar 23, 2023 7:03 pm
by k2yn
Does anyone have a display flicker . It is very fast and happens about every minute. I am running an ANAN 7000dle and a GTX 1050 video card in the PC. I am using the latest software (2.9.0.8) and firmware (2.1.18). Anyone have this situation??? John K2YN
Re: display flicker
Posted: Thu Mar 23, 2023 9:51 pm
main spectrum area flickering, or meter containers, or both?
Re: display flicker
Posted: Fri Mar 24, 2023 2:40 pm
by k2yn
Hi Ramdor...the main display jumps every few minutes and affects the audio too. It pops abit when it flickers. John K2YN
Re: display flicker
Posted: Fri Mar 24, 2023 2:59 pm
John--did something change to make this happen? Are you saying it's a problem with 2.9.0.8? If you are, did you revert back to 2.9.0.6 to confirm the problem goes away when you do?
Re: display flicker
Posted: Fri Mar 24, 2023 3:32 pm
there are some gpu threading changes in test release versions of 2.9.0.8 that a few people are testing. This has fixed some flickering in meters that had been observed (not happening in the main spectrum area). This will be out for testing next week sometime when I have looked at the export/import db issue(s).
Are you using any containers/additional meters, if so remove them for now, but sound/display/etc pops are more than likely something else (network/etc/etc).
Re: display flicker
Posted: Fri Mar 24, 2023 4:04 pm
by k2yn
Ramdor..I am using no extra confusing systems. I am running without VAC and no extra meters. In fact I am not using the new meters available yet. I believe it was happening before on 2.9.0.6 Ramdor. I will back load an earlier version of Thetis and see if it happens. John K2YN
Re: display flicker
Posted: Fri Mar 24, 2023 4:39 pm
If it happens with 2.9.0.6 then it's not Thetis, it's something else.
Re: display flicker
Posted: Fri Mar 24, 2023 8:29 pm
by k2yn
OK !! I will go back one version and check. Thanks for your feedback Ramdor. John K2YN
Re: display flicker
Posted: Fri Mar 24, 2023 11:24 pm
by k2yn
Well Ramdor the problem is apparently mine. I tried 2.9.0.6 and had the problem. It's like the port is checking itself. Anyway... Thanks for your help Ramdor and thanks for the improvements you develop!!! John K2YN
