Thetis & Hermes Lite 2 (HL2)
vk7zpd
Re: Voice Squelch Theory and Operation
Post by vk7zpd »
I notice that the voice squelch option is not availabla in the 2.9.0.8 x64 HL2 Beta 1, is there a later release for the HL2 that has the Voice squelch functionality?
Phil
I'm not familiar with that version. Unsurprising since this is an Apache hardware-centric forum.
Doesn't the regular 2.9.0.8 set for Hermes work with the HL2?
Trucker
Post by Trucker »
vk7zpd wrote:I notice that the voice squelch option is not availabla in the 2.9.0.8 x64 HL2 Beta 1, is there a later release for the HL2 that has the Voice squelch functionality?
Phil
You may need to ask that on the Hermes Lite 2 Google groups list. I kind of doubt it as Reid is still working on the beta he released a while back.
vk7zpd
Post by vk7zpd »
w-u-2-o wrote: Doesn't the regular 2.9.0.8 set for Hermes work with the HL2?
That’s something I’d like to know as well, is Reid’s build just pre-filling and inhibiting unavailable settings or is it adressing hardware differences, I did ask on the Google HL2 group if Reid has a time frame for releasing a patch of the latest 2.9.0.8. He indicated that he wasn’t sure.
nobba
Post by nobba »
vk7zpd wrote:
w-u-2-o wrote: ... Reid’s build just pre-filling and inhibiting unavailable settings or is it adressing hardware differences, I did ask on the Google HL2 group if Reid has a time frame for releasing a patch of the latest 2.9.0.8. He indicated that he wasn’t sure.
Reid doesn't 'just' do anything. He has a really hard job because upstream is not interested in incorporating his changes. Therefore, with each an every new release, Reid has to painstakingly go back over and "re-add" all of his changes all over again. It's actually quite clever how he does it, and requires patience and a lot of persistence. Whereas if it was accepted upstream, it would be automatically in the build each time.
Since there is every likelihood of more changes soon for the G2 (assuming Richie actually accepts the pull request for it), so if I were him I would hold off until it is a stable root once more. Otherwise it will be double the work for him.
Since Scott has the source code for my last Thetis update, perhaps if you ask him nicely, he will put a voice squelch button on it for you. All the code is present but it is just not 'wired up' to any UI.
HTH,
Steve
GL es 73
Steve, G7KLJ
Re: Thetis & Hermes Lite 2 (HL2)
I can build but I can't code! However, the code is available for anyone who wants it: https://github.com/w-u-2-o/Thetis-2.9.0
