Procedure for full backup of Thetis, or if it refuses to start
Postby w-u-2-o » Tue Jul 11, 2023 7:34 pm
To make a complete backup of your Thetis environment (64 bit), make copies of the following two folders:
C:\Program Files\OpenHPSDR\Thetis
C:\Users\<your windows username goes here>\AppData\Roaming\OpenHPSDR\Thetis-x64
Then no matter what you do after that, if your replace those folders from your backup copies all will be as it was, with the possible exception of start menu shortcuts.
If you are in a situation where you are trying to upgrade and you can't get the new version to run, or something is just going crazy and Thetis won't start even with a reset database, then make a copy (just in case) of:
Then delete that original folder completely and try again.
Trucker
Re: Procedure for full backup of Thetis, or if it refuses to start
Postby Trucker » Tue Jul 11, 2023 7:59 pm
Scott, if I remember correctly, you have to have Administrator privileges in order to see the app data subfolder. I think you may have mentioned that in an older post when this same issue came up.
Postby w-u-2-o » Tue Jul 11, 2023 8:33 pm
If you own the PC that shouldn't be a problem, James.
Trucker
Postby Trucker » Wed Jul 12, 2023 12:40 am
viewtopic.php?f=9&t=4572&hilit=Backup
This is the procedure I have followed before installing updates.
If I wasn't running as Administrator, then the above was necessary to see the appdata subfolder in order to make a backup before installing a new version.
and yes, I do own the pc. ( several in fact)
Postby w-u-2-o » Wed Jul 12, 2023 1:10 am
There's no difference in those procedures, James, so I'm not sure what you are getting at.
Trucker
Postby Trucker » Wed Jul 12, 2023 2:19 am
w-u-2-o wrote:There's no difference in those procedures, James, so I'm not sure what you are getting at.
In the link I posted you mention the fact that the folders that need to be copied for backup are " hidden " folders. And then you detail how to access them. In the procedure you describe in this thread, you Leave that bit of information out. I wasn't trying to be critical or anything like that. But, when I first started making a backup before installing a new version, I found the other thread and found it useful.
That really helped me at the time. So,when I saw that detail was missing in this thread I thought maybe you just overlooked it. Again, not being critical. Just wanted to save others from wondering what they were doing wrong when they couldn't find the appdata subfolder.
JJ4SDR
Postby JJ4SDR » Thu Nov 30, 2023 12:52 am
Not sure if what I have been doing is wrong, but I have copied the OpenHPSDR folders in their entirety rather than only the Thetis subfolders next level down from OpenHPSDR folders as shown below. Could this way of backing things up end up causing issues that normally don't show up?
C:\Users\<my Windows username>\AppData\Roaming\OpenHPSDR
Thetis v2.10.4.3 x64
Protocol 2 v2.1.18
Postby w-u-2-o » Thu Nov 30, 2023 2:35 am
Not that I'm aware of.
