Record & Playback with VAC
Posted: Wed Nov 01, 2023 12:09 am
I have had my G-2 plain panel for a few months now. Thetis and firmware updates have each gone smoothly.
Previously, using my 7000DLE Mark III, I was accustomed to using the REC & PLAY button to sample my signal and play back received signals.
After the G-2 arrived and the Balanced mic input was added to Thetis, I had the ECHO problem on my transmitted signal. I could not get rid of it using several RFI chokes, etc. So I abandoned using the BAL mic input. I went to using VAC with an SSL2 audio interface. I am mostly happy (though confused sometimes) with this set up. I use a Neumann KMS 105 condenser microphone.
Now the REC & PLAY buttons don't work. I am guessing that going to VAC caused this.
How do I restore the REC & PLAY functionality I had before? Is there a setting I need to change? Do I need to use VoiceMeeter Banana?
Seems to me that this should be simple.
Can someone explain how to do this? Thanks!!
73 Torrey N9PY
73 Torrey N9PY
