Dear Thetis community, I am thinking of purchasing an ANAN TRX and maybe moving away from Flexradio. Therefore I do have to understand something regarding Thetis/Anan.
Since I am using the Flexradio PowerGenius amplifier I need two PTT Outs A/B in order to use SO2R.
Within Setup/General/OC/HF Control there are possibilities to use the PINs of the OC 9 Pin Connector on the back.
Am I right that with this configuration when I "ptt" 160-40m I will have OC out 1 triggered and for 20/15/10/6m I will have OC 2 triggered?
With this I could VFO A (TX) (using bands 10-20m) trigger PTT on Port A of PGXL and VFO B (TX) trigger PTT on Port B of PGXL.
With Flex ANT1 TX always triggers Port A PGXL and ANT2 TX always triggers Port B PGXL which is more convenient since I do not have to define bands (if the above works) to TX ports.
If there is a possibility to poll via CAT which VFO has "TX active" I could just switch the "PTT Out" of the Anan to the respective port with node red triggering a relayboard. Therefor I would have more flexibility.
This would also account for the "-60dBc output signal" ports at the PGXL since the feedback has to come from the transmitting port. I thought of just coupling it with -3db wilkinson power divider so that I only have one feedback line to the Anan => thoughts?
Withhin Thetis I configured XVTR and assigned buttons 0/1 (VHF/UHF). I see that Setup/General/OC/VHF I do have a matrix as well. Are the "Bands" linked to the XVTR setup? So that when in VHF/UHF mode I can trigger specific OC Pins to have PTT on my transverters or will it be defined by the input frequency (28MHz)?
For freuqency CAT output I understood that I can just open a port Setup/General/Serial/Serial. Since VFO A/B are not distinguished here (At Flex you can define Freq output for VFO A/B seperatly) I will be using node red to poll VFO A/B (with proper CAT commands), to send it to my PGXL/TGXL/AG2x8.
Thanks for taking the time. If something is not clear I´ll try to sort it out. Just for everyone´s understanding I do not have an ANAN yet and have to figure out abvove points to make a decision.
Thanks a lot,
73 de Volker, DL4RCE
- Board index Client Software Discussion Thetis
- Search
- It is currently Sat May 04, 2024 4:04 am
- All times are UTC
OC Control / XTRV / PureSignal
Jump to
- Apache Labs News
- Apache Labs News
- Client Software Discussion
- Thetis
- piHPSDR
- G2 Operating System & Applications
- PureSignal Operations (PowerSDR & Thetis)
- Diversity Operations (PowerSDR & Thetis)
- Macro & MIDI Controller Software, Hardware & Scripts
- PowerSDR mRX
- linHPSDR
- SDR Console
- All Other Clients
- Network Connections & Network Hardware
- Remote Operation Over The Internet
- Microphones, Speakers & Audio Hardware
- Digital ("Virtual") Audio
- Keys, Keyers, Paddles & Bugs
- Amplifiers & Tuners
- Digital Mode, Rig Control & Logging Software
- Transverters
- Apache-specific Hardware Discussions
- Everything Else: Antennas, Relays, Switches, Power, Grounding, Cooling, etc.
- PC's & Homebrew Hardware
- Firmware Discussion
- Upgrading/Downgrading
- Protocol 2 Firmware (all radios)
- Orion Mk II & III Firmware (all 7000, 8000 & Andromeda Variants)
- Orion Firmware (200D)
- Angelia Firmware (100D)
- Hermes Firmware (10 & 100)
- Hermes 14-bit Firmware (10E, 100B)
- Legacy Yahoo Group Files
- Other Topics
- Sales, Delivery, Warranty & Repair Discussions
- Forum Problems (like posting photos, etc.)
- Equipment Exchange
- Apache Labs Radios: Buy/Sell/Trade
