Was working perfectly. In fact just ran the whole CQ160 WW with no issues. Went to restart and Thetis shows error box when trying to power on saying "Error starting SDR hardware"
On the lan connection the left light is on but the right blinks for a while when the cable is first connected then stops.
I am running the V2 10.3.5x64 u2 version of Thetis with protocol 2.
I tried with a completely different computer and same issue. with a fresh install of Thetis.
There was absolutely no error when I powered the radio off this morning. And no lightening strikes or anything like that.
I'm baffled. Any hints?
Ron
N4XD
Thetis doesn't see Anan 7000dle
Re: Thetis doesn't see Anan 7000dle
Found issue. User error. I had moved the radio and, somehow, flipped the switch on the bottom to boot loader. Moved it back and all is good. Sorry for the bandwidth
Ron
Ron
I had exactly the same case with my ANAN 8000. While connecting the antenna cable, I accidentally switched the switch to the Boot Loader position. As a result, it became impossible to connect via LAN. At first I thought that the network card in the TRX was damaged. This post helped me quickly find the reason for the TRX not working.
