RX Ant Selector
W1RHS
RX Ant Selector
Postby W1RHS » Wed Feb 07, 2024 12:43 am
I connected a second antenna to Ant 2. I can switch between Rx Ant 1 and Rx Ant 2 using the Thetis selector at the bottom of the UI. I can also configure the antennas by band in Setup, Ant/Filters tab. However, UI selector only works when the VFO is in the Ham Bands. When I go out of the Ham Bands the Ant Selector in the UI has no effect. I can change the Rx antenna using the Setup, Ant/Filters screen when out of the Ham Bands by changing the Ham Band antenna closest to the Rx frequency. I use the Anan for SWL so it's an extra step to change RX Antenna when listening outside the Ham Bands. Am I missing something? I am running Thetis 2.10.3.6 dev_2 with P2 fw 2.1.18. Thanks!
Rick, W1RHS
7000DLE MKII
W1RHS
Re: RX Ant Selector
Postby W1RHS » Fri Feb 09, 2024 4:18 pm
I opened a BUG on this and received a reply from Richie. Apparently this behavior is functioning as designed. The Antenna Selector in the GUI only works when within the Ham Bands. -Rick
Yes the implementation is to only work with ham bands.
// set RX antenna to new antenna 1-3
// this must also cancel any ext input check boxes
public void SetRXAntenna(int Antenna, Band band)
**if ((band >= Band.B160M) && (band <= Band.B6M))*
Rick, W1RHS
7000DLE MKII
PD3LK
Re: RX Ant Selector
Postby PD3LK » Fri Feb 09, 2024 7:55 pm
That makes my problem clear too. Spended a "few" hours in vaine on this to get it right :(
Very pitty for users (like me) who use there radio only for listning to utility, mil, and air traffic, and use multiple RX antenna's.
I rather don't use antenna port 1 for RX to protect some expensive active antenna's. (in case of accidental TX)
Richie, is it possible to make this optional? Or bypass this when TX has been disabled?
regards
