LED Mirror on setup F/W set window (FW 2.2.2)
Posted: Fri Feb 09, 2024 4:30 pm
by I2NOY
I noted that I have LED #2 lighted in red with 7000DLE mkII firmware 2.2.2.
With firmware 2.1.8 every LED is grey.
What "LED Mirror" does it mean?
Sameone can explain briefly or send a link where can I find an explanation?
Maurizio I2NOY
Re: LED Mirror on setup F/W set window (FW 2.2.2)
Posted: Fri Feb 09, 2024 5:52 pm
by W1AEX
Hi Maurizio,
There was some discussion of this back in April of 2022 with some speculation that it was for debugging purposes. See link below.
https://community.apache-labs.com/viewtopic.php?f=9&t=4135&p=19374&hilit=LED+Mirror#p19374
Posted: Fri Feb 09, 2024 6:51 pm
by n1gp
The LED Mirror is meant to be used for debugging purposes and represents
data that the firmware wants to show the user via the client app. I had enabled
LED1 and LED2 to show which Ethernet Phy chip was installed on the Orion
board. It can be either a KSZ9021 or KSZ9031.
If LED1 is lit then its a KSZ9021 else if LED2 is lit its a KSZ9031.
There is support for both in the firmware.
-Rick / N1GP
Posted: Sat Feb 10, 2024 9:14 am
by I2NOY
Many thanks!
