Thetis and openhpsdr mrx ps and Thetis
Posted: Wed Feb 14, 2024 9:45 am
Hi all ,
question : is it OK to get Thetis and HPSDR both installed on a PC and sometimes run Thetis , sometimes run hpsdr?
Actually I run only HPSDR but there is someting boring : depending how I use it , I need the setup to be different so I need to modify manually every time.
So different software with it's own setup would be better . I suppose it is not possible to run sevral HPSDR as probably the database would be the same whatever instance is used?
Another boring thing , the PTT setup with serial ports is not kept in the database , very often I have to re^program PTT and com but I know there is no longer development on HPSDR.
It is the same with frequency memories , sometimes wiped.
Dom
Dom
