Auto Power on not working
w8du
Postby w8du » Tue Feb 27, 2024 4:20 pm
Just installed Thetis 2.10.3.5 as well as Protocol 2 Firmware 2.2.2. Everything installed with no errors. However, checking the Auto Power on at Startup box under Settings/General/Options/Options-2 seems to no have any effect. That is, the radio does not power on when I start Thetis.
My radio is a 7000DLEMk2, low s/n. Does the auto power on no work with this radio?
Tnx es 73 de Arnie W8DU
Re: Auto Power on not working
Postby Tony EI7BMB » Tue Feb 27, 2024 4:37 pm
Works ok with my 7000
Alex A
Postby Alex A » Tue Feb 27, 2024 5:34 pm
Hermes protocol 1 /Thetis v.2.10.3.6x64.
Everything works perfectly.
Alex Akramov EW3KO
w8du
Postby w8du » Tue Feb 27, 2024 6:27 pm
Are you running the 7000DLEMk2? If so, which version of the radio? Mine is one of the very early ones. Maybe the auto power on only works on later ones?
Alex A
Postby Alex A » Tue Feb 27, 2024 6:53 pm
w8du wrote: Mine is one of the very early ones.
I think my SDR Hermes board is even earlier...
Works with the first protocol.
No complaints.
Alex Akramov EW3KO
GW4NNO
Postby GW4NNO » Tue Feb 27, 2024 9:24 pm
Maybe you are a little confused by this feature? when you say "That is, the radio does not power on when I start Thetis." This feature is actually just to auto press the power button within Thetis itself to start the connection with your radio and initiate operation. You still need to press the actual physical power button on the radio itself to switch power on to it, then when you start Thetis with this option enabled you don't need to press the power button within Thetis, i.e. operation of the radio will start as soon as Thetis connects your radio and activates it.
73 Terry GW4NNO
w8du
Postby w8du » Tue Feb 27, 2024 10:34 pm
Thank you Terry! So, in other words, it just does the same thing as adding "-autostart" to the desktop program shortcut? It does not have anything to do with powering on the hardware. Now I understand.
Cheers....73 de Arnie W8DU
GW4NNO
Postby GW4NNO » Tue Feb 27, 2024 10:39 pm
Yes, it just starts your radio shortly after Thetis is run without you having to press the power button in Thetis! You have it correct now.
Terry GW4NNO
Postby w-u-2-o » Wed Feb 28, 2024 12:37 am
Labeling that button "Power" is one of the least comprehensible things in the history of PowerSDR/Thetis. I made a custom button for my skin that is labeled "Run" and "Stop", a much more accurate representation of the state of the software, and only the software. The button has nothing to do with the firmware or the hardware.
w8du
Postby w8du » Wed Feb 28, 2024 2:35 am
Agree. It mislead me, for one.
KA5KKT
Postby KA5KKT » Wed Feb 28, 2024 3:47 am
Hi Scott.
"I made a custom buttons for my skin that is labeled "Run" and "Stop"...
Do you care to post them or perhaps a link?
Kind regards,
Dick - KA5KKT
Postby Tony EI7BMB » Wed Feb 28, 2024 10:56 am
I use the RZ1ZR skin which has START button
w9ac
Postby w9ac » Wed Feb 28, 2024 2:12 pm
Tony EI7BMB wrote:I use the RZ1ZR skin which has START button
As do the KE9NS variants.
KA5KKT
Postby KA5KKT » Wed Feb 28, 2024 7:41 pm
Thanks fellas!
