Thetis 2.7.0
Thetis 2.7.0
FYI, Thetis 2.7.0 sources out now.
https://github.com/w5wc/Thetis-2.7.0
Compiled it yesterday and did a short test.
Look's OK so far, but have to play around a bit more.
Re: Thetis 2.7.0
Hi Sigi,
I would like to test your compiled files. I don't know how to compile the sources on my windows pc, maybe we can talk by phone oder teamspeak.
Re: Thetis 2.7.0
Hi Sigi,
I did install Visual Studio 2019 yesterday and it seems to works. Just tested the self-compiled 2.6.9 and 2.7.0.
I just tried to TX with my 2-m-band-xvtr, but failed due to not working ptt control. The xvtr ptt is connected to the rear panel rca jack on my ANAN-7000.
I switched back to 2.6.9c3 by Richie.
Re: Thetis 2.7.0
Compiled it too.
Played a bit with the Release version. Looks good so far.
73 Isaac 4Z1AO
73 Isaac 4Z1AO
Re: Thetis 2.7.0
Hi Isaac,4z1ao wrote:Compiled it too.
can you please try to setup for a 2-m-xvtr and check the ptt output on your radio?
Re: Thetis 2.7.0
Are there any release notes for 2.7.0? Can anyone summarize the difference between this version and 2.6.9?
Jeff NJ2US
Jeff NJ2US
Re: Thetis 2.7.0
I recommend to ask Richie about the changes.DL8LAQ wrote: I switched back to 2.6.9c3 by Richie.
Maybe he could point you in the right direction.
too bad that Richies source files are not visible, otherwise you could search for the differences in the XVTR control yourself. Today I try to connect the Alex interface and report back what the XVTR PTT does for me.
Re: Thetis 2.7.0
AFAIK, Richie is taking a break from coding. That means any changes are most likely from Doug and Laurence and associated with the Andromeda project.
Re: Thetis 2.7.0
It's kind of difficult to know, because 2.7.0 has forked off into a completely new git repository, and so we can't do a simple diff to see all the changes.jeffreydoran wrote:Are there any release notes for 2.7.0? Can anyone summarize the difference between this version and 2.6.9?
Jeff NJ2US
I just did a file compare in WinMerge between 2.6.9 and 2.7.0 in W5WC's GitHub. All the low level stuff is exactly the same, ie zero changes in WDSP and The ChannelMaster. Many changes were done in the Console and Setup classes. The Console is a scary and confusing place that dates all the way back to the SDR-1000 days at Flex, so it's hard for me to understand what all the changed were. My sense, after scanning quickly through all the changes, is there was a lot of code cleanup, housekeeping, and some modest refactoring in Console and Setup.
Re: Thetis 2.7.0
I'll try and let you know.DL8LAQ wrote: Hi Isaac,
Re: Thetis 2.7.0
I think it's ok now with f/w Orion_MkII_NP_v2.0b! Now I can use the self-compiled 2.7.0. The footswitch is working in CW and the PTT out is active, that means the PA PTT or the XVTR is controlled by footswitch! That is what I missed for long time!!!!4z1ao wrote:I'll try and let you know.DL8LAQ wrote: can you please try to setup for a 2-m-xvtr and check the ptt output on your radio?
By the way, the PTT by space bar seems to not work now - yes, I enabled MOX by space bar - but that is no problem since the footswitch is available in any mode.
Thank you guys for fixing this
Re: Thetis 2.7.0
Hello Norbert,
good to hear it is working now.
For spacebar PTT have a look at the pic.
Re: Thetis 2.7.0
Hi Sigi,DH1KLM wrote:Hello Norbert,
that is the solution. Thank you!
Re: Thetis 2.7.0
Space bar working Norbert , thank you very much .
Chris
GW0DQW
Re: Thetis 2.7.0
have compiled thetis 2.7.0, if you want to test, please ...
https://www.file-upload.net/download-13 ... 0.zip.html
Re: Thetis 2.7.0
Thanks but could not get this working, radio would not switch on . back to 2.6.9
dj1yr wrote:have compiled thetis 2.7.0, if you want to test, please ...
Re: Thetis 2.7.0
Did you choose the right radio?
Re: Thetis 2.7.0
I presume so as it updated existing database.
Re: Thetis 2.7.0
I had the same experience when updating an existing database.
Obviously the radio model is not updated in Setup> General> H / W Select.
I noticed this behavior even after importing an older database. The radio was then set to HPSDR instead of Hermes.
But I think that most of the other settings were adopted, at least I could not find any other differences.
Re: Thetis 2.7.0
It was the same with me
Re: Thetis 2.7.0
Thanks guys you were right, the correct radio was not selected . Seems to be working on RX so far.
Re: Thetis 2.7.0
2.7.0 does not seem to remember the last TX mode on startup , anyone else seeing this ?
Re: Thetis 2.7.0
I'm having no issues with Thetis 2.7.0 remembering the TX mode on startup
Re: Thetis 2.7.0
After the first start of 2.7.0 under General -> H/W Select the correct transceiver was not taken over.
Also the audio profile (Transmit Filter as well as CFC settings) had to be adjusted.
All other settings like PA Settings, Display, CAT were taken over from 2.6.9.
Marcus
Re: Thetis 2.7.0
Yes the database upgrade did not capture the mode so has to be set correctly and saved again under the correct TX profile.
Edit: Tested again and the program resets every time to LSB when profile was set to DIGU
Re: Thetis 2.7.0
In this case yes. The first time I started 2.7.0 I had to go through and correct many settings that did not come over from 2.6.9. After that I had no issues.
Re: Thetis 2.7.0
Yep definitely an issue here , no matter what I do it goes back to LSB on startup unless I'm missing something obvious. Not a big deal either way
dalemitchell
Re: Thetis 2.7.0
Where can i download Thetis 2.7.0 $
Re: Thetis 2.7.0
dalemitchell
Re: Thetis 2.7.0
Dale
Dale
