w-u-2-o wrote:db8gk wrote:The Bootloader source can be found under "openHPSDR-Protocol1-Programmers".
Hah, apparently I just didn't dig deep enough. Thanks! Builds from source, let's see.
NN3RP wrote:If it helps, WSJT-X needs / demands your PC to have time synchronized with time server, i.e., using Dimension 4 software or other. Otherwise you will not be heard. I've been there done that.
Rafael / NN3RP
That is correct.w0ivj wrote:I am running an ANAN 7000DLE MKII with PoweSDR mRX v.3.4.9(3/19/18) using Protocol 1 Orion_MKII_v2.7_K5SO_5-4.rbf. It seems to work perfectly. When I switched to Thetis v2.6.9 (1/25/20) using Protocol 2 Orion_MKII_Protocol_2v1.9.rbf, I experienced what I think is called (elevated noise floor of doom). I understand that this results from timing errors in the firmware that happens with some hardware.
That certainly won't, it's a Protocol 1 firmware build and Thetis requires Protocol 2 firmware to be loaded.In an attempt to solve this, I reverted to some different versions of P2 firmware. Here is a list of Protocol 2 firmware that I tried and some of the problems:
metis_Orion_MkII_v2.7_K5SO_5-4.rbf will not connect
You will have to go back up to the beginning of this topic (the first post) and continue to try different versions of firmware until you find one that works. Very rarely someone will find they are in the unfortunately position of owning a serial number that will not work with any available version of P2 firmware. Let's hope that's not the case here. But you have many other versions to try still.metis_Orion_MkII_Prorocol_2_v2.0b.rbf puresignal will not work
metis_Orion_MkII_Protocol_2_v1.9.rbf noise floor of doom
metis_Orion_MkII_Protocol_2_v2.0_pre1.rbf This file works with no raised noise floor and puresignal but has popping audio, spectrum jumps on tune, and many sequence errors.
w-u-2-o wrote:I'd recommend you try a different version of the P2 firmware. Go back to the first post in this topic and pick a few to download and try. You may even need to go back to 1.9 or possibly 1.8 series revisions.
Code: Select all
2021/05/12 17:53:49 Unknown: (d8:80:39:6f:92:3b) (192.168.0.6:1024)
2021/05/12 17:53:49
2021/05/12 17:53:49 Board Type: Unknown
2021/05/12 17:53:49 HPSDR Board: (d8:80:39:6f:92:3b)
2021/05/12 17:53:49 Board Address: 192.168.0.6:1024
2021/05/12 17:53:49 Protocol: 3.8
2021/05/12 17:53:49 Firmware: 1.9
2021/05/12 17:53:49 Receivers: 4
2021/05/12 17:53:49 Freq. Input: Phase_word
2021/05/12 17:53:49 Status: not running
2021/05/12 17:55:16 Served Program Interface page.
2021/05/12 17:55:24 Served Upload Interface page.
2021/05/12 17:55:24 Directory /home/hellmind/Downloads/HPSDRfiles/ created
2021/05/12 17:55:24 /home/hellmind/Downloads/HPSDRfiles/Orion_MkII_Protocol_2_v1.9.rbf
2021/05/12 17:55:24 Looking for rbf file: /home/hellmind/Downloads/HPSDRfiles/Orion_MkII_Protocol_2_v1.9.rbf
2021/05/12 17:55:24 Programming the HPSDR Board
2021/05/12 17:55:24 Found rbf file: /home/hellmind/Downloads/HPSDRfiles/Orion_MkII_Protocol_2_v1.9.rbf
2021/05/12 17:55:24 Size rbf file: 1727508
2021/05/12 17:55:24 Size rbf in memory: 1727744
2021/05/12 17:55:24 Packets: 6749
2021/05/12 17:55:26 Served Program Interface page.
2021/05/12 17:55:26 Looking for rbf file: /home/hellmind/Downloads/HPSDRfiles/Orion_MkII_Protocol_2_v1.9.rbf
2021/05/12 17:55:26 Erase: 192.168.0.5:1024 -> 192.168.0.6:1024
2021/05/12 17:55:26 Erase: After Makepacket
2021/05/12 17:55:26 Erase: After Comlink
2021/05/12 17:55:26 Erase: After Commpacket [0 0 0 0 4 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0]
Code: Select all
[hellmind@workstation programmer]$ ./HPSDRProgrammer_cmd -index 2 -selectMAC d8:80:39:6f:92:3b -setRBF ../Metis_Orion_MkII_Protocol_2_v2.0b.rbf
2021/05/12 18:03:09 Computer: (82:74:81:eb:d2:4c)
2021/05/12 18:03:09 OS: linux (amd64) 12 CPU(s)
2021/05/12 18:03:09 Username: (hellmind) /home/hellmind
2021/05/12 18:03:09 IPV4: 192.168.0.5
2021/05/12 18:03:09 IPV6: fe80::8074:81ff:feeb:d24c
2021/05/12 18:03:09 Discover: 192.168.0.5:0 -> 255.255.255.255:1024
2021/05/12 18:03:09 Received data: 60 bytes from 192.168.0.6:1024
2021/05/12 18:03:09
2021/05/12 18:03:09 Board Type: Unknown
2021/05/12 18:03:09 HPSDR Board: (d8:80:39:6f:92:3b)
2021/05/12 18:03:09 Board Address: 192.168.0.6:1024
2021/05/12 18:03:09 Protocol: 3.8
2021/05/12 18:03:09 Firmware: 1.9
2021/05/12 18:03:09 Receivers: 4
2021/05/12 18:03:09 Freq. Input: Phase_word
2021/05/12 18:03:09 Status: not running
2021/05/12 18:03:09 Selected MAC: (d8:80:39:6f:92:3b) Unknown
2021/05/12 18:03:09
Input Check: RBF name "../Metis_Orion_MkII_Protocol_2_v2.0b.rbf" and selectedMAC board name "Unknown" (d8:80:39:6f:92:3b) do not match!
2021/05/12 18:03:09 Please correct to program the board.
LU2FAF wrote:Can I use this firmware for my Orion MK2 board ?, isnt 7000/8000
