Thetis 2.8.11 Released!
Re: Thetis 2.8.11 Released!
W1JA wrote:2.8.11
x64
200D
Protocol 2
2.7.0 a3 did not have this issue.
73, John W1JA
What happens if you go back to 2.7 now? Have you actually tried that?
GW0DQW
Post by GW0DQW »
Hi there,
Check that the sampling is the same for both RX1 and RX2 in :=
General - F/W Set, mine are 19200.
Hope this may help.
Regards Chris GW0DQW
W1JA
Post by W1JA »
w-u-2-o wrote: What happens if you go back to 2.7 now? Have you actually tried that?
I hadn't, but I'm trying right now. I'm surprised to find the same glitches, actually much worse than yesterday. I don't understand. I've been using RX2 successfully, under these same setup and use conditions, for years. Did 2.8.11 break my 200D or my firmware? :?
Lots of seq. errors, so I made an effort to read some of them.
280 DDC2 DDC3 Mic
272 (didn't capture the text after the number)
24 DDC2 DDC3
16 (didn't capture the text after the number)
8 DDC2
(Aside: Sure would be nice of the error text stayed around for a full second or two. :( (Unless this information is of no value.)
GW0DQW wrote: Check that the sampling is the same for both RX1 and RX2
The are not the same; RX1 is 384000, RX2 is 1536000. I have used these rates, with Protocol 2 and Thetis, without issues for about two years. Anyway, I tried setting RX2 to 384000 same as RX1, no improvement.
No version of PowerSDR or Thetis can break your firmware or hardware.
That was a good experiment. It proves something else change that is not related to Thetis.
Things that may have changed: something in Windows, something on your network, maybe your database is corrupt (try a fresh one), maybe your firmware is corrupt and needs to be reloaded (VERY unlikely), or maybe...the temperature of the radio.
Why radio temperature, you ask? Because Protocol 2 firmware timing closure is very sketchy and can be very sensitive to the temperature of the FPGA. In the absence of gross networking problems, Seq errors are nearly always associated with the firmware struggling to work, i.e. poor timing closure. Has the room you are in become noticeable cooler or warmer because it is now Winter? If so then you may need to try a different version of the firmware to find one that is stable for you under present conditions.
ea3aqr
Post by ea3aqr »
280 DDC2 DDC3 Mic
24 DDC2 DDC3
8 DDC2
Have your Windows 10 recently upgrade to v.2004 or v.20H2?
If yes, that's your problem...
W1JA
Post by W1JA »
w-u-2-o wrote:No version of PowerSDR or Thetis can break your firmware or hardware.
There was no smiley for tongue-in-cheek, but that's how I meant my statement.
ea3aqr wrote:Have your Windows 10 recently upgrade to v.2004 or v.20H2? If yes, that's your problem...
I hadn't used RX2 in about a week. In between last use of RX2 and upgrade to 2.8.11 was... Windows upgraded itself to v2004. I will roll back to 1909 and test again.
W2PA
Post by W2PA »
I'm hearing the same glitches in 2.8.11 - on RX2 only. They are present to the same degree in both the 32-bit and 64-bit versions.
No glitches heard with 2.7.0.
I'm also running Windows 10 v 2004.
Will continue to test variations.
Chris, W2PA
W1JA
Post by W1JA »
Before rolling back my Windows version, I tried fiddling with some of the options available in Properties for my Ethernet adapter (Intel I219-V) driver. I don't know what most of the options are for, really, so I picked some (buffer sizes, energy options, jumbo packet...) that seemed like they might be relevant. Nothing I did made any difference.
I also installed the latest (dated Oct 2020) driver from Intel. The glitches persisted.
Finally, I reverted to Windows v1909. The glitches are gone, both on 2.7.0 and 2.8.11.
w3ub
Post by w3ub »
Here is a good reference from the Flex Radio guys on Ethernet properties that helped me.
https://helpdesk.flexradio.com/hc/en-us ... erformance
/Doug
W1JA
Post by W1JA »
Thanks Doug. When I did my "fiddling with some of the options available in Properties for my Ethernet adapter," I already tried everything in steps 1 through 3 in that Flex document, and the first 3 items in step 4. None made any difference. I didn't try of the last things in step 4, starting with Descriptors and proceeding to the end.
What did make a difference is going back to Windows version 1909. The problem went away completely. For now I will stay with 1909, and I have Windows set to block any Feature upgrades for one year. Perhaps I will try version 2004 again. I made a system drive image with 2004, so I could go back fairly easily, try the remaining things in the Flex document, and if they don't work, return to 1909. Maybe I will do this, someday.
73, John W1JA
liam
Post by liam »
HI I have the same problem with A8k and W 10 x 64 updating even when updates have
been off so Now I use a PC only for the radio however when I connect to a cluster or N1MM
connects to the net the updates often start no matter what my metered setting ,,,, I have found this program helps block updates far better than
the onboard W 10 setting
https://www.majorgeeks.com/files/detail ... ocker.html
72
Liam ei3gc
I4LEC
Post by I4LEC »
If not already reported, noticed that, even if checked, the "Auto Mode Swch" does not move the radio to CW once the paddles are used.
Thanks and 73, Clay
WA1NVC
Post by WA1NVC »
ANAN-100D Protocol 1 Thetis 2.8.11 64 bit
I noticed that RX2 was NOT connected to the RX2 jack with Thetis 2.8.9 so I upgraded to Thetis 2.8.11.
RX2 is still connected to ANT1 just like the main receiver.
FWIW PI shows RX2 connected to the RX2 jack.
According to the release notes this should have been fixed.
PowerSDR works correctly.
Roger
WA1NVC
2.8.11 now available.
- Fix: L/R pan behavior for P1/P2
- Fix: step attenuator display behavior for RX2
- Fix: CAT command ZZTO not working correctly
- Fix: RX2 freq not updating for Hermes
* Fix: RX2 ADC assignment wrong for 5 DDC boards on P1
- Fix: installer hangs on removing shortcuts
- Fix: CFC disabled/enabled during/after quick playback
- Fix: O/C ext control not turning off outputs
- Fix: VFO A lock not locking the band buttons
- Fix: antenna selection not displaying correctly when in SWL
Are you able to fix the problem by manually selecting the ADC assignment in setup?
Did you try a fresh database?
w8du
Post by w8du »
How do you revert to a prior release of Windows?
Tnx de Arnie W8DU
W1JA wrote:Before rolling back my Windows version, I tried fiddling with some of the options available in Properties for my Ethernet adapter (Intel I219-V) driver. I don't know what most of the options are for, really, so I picked some (buffer sizes, energy options, jumbo packet...) that seemed like they might be relevant. Nothing I did made any difference.
WA1NVC
Post by WA1NVC »
The upgrade from 2.8.9 to 2.8.11 does a database refresh. I did another after upgrading and neither fixed the problem.
I started trying all the possible selections on the ADC screen to get the desired behavior.
On PowerSDR, DDC0 is connected to ADC0 and DDC1 is connected to ADC1. The Thetis default is the same. I am running Protocol 1 on my ANAN-100D.
However changing DDC2 to be connected to ADC1 looks like I am getting the desired result. See the attached screenshot.
With two antennas, testing shows signals on the ANT1 connector appear only on the main RX display and signals on the RX2 connector only appear on the RX2 display.
Roger
WA1NVC
P.S. Thanks for fixing the RX2 gain; it is now sticky rather than full volume each time RX2 is turned on.
The DDC assignments in Thetis have always been different than in PowerSDR. Glad you got it sorted.
W1JA
Post by W1JA »
w8du wrote:How do you revert to a prior release of Windows?
Tnx de Arnie W8DU
Arnie, sorry my reply is late. I've been away from the forum for too long. If you decide to revert soon enough (within 10 days, I think), go to Settings > Windows Update, and click Recovery on the left sidebar.
Also, I make frequent image backups of my system drive. If it's past 10 days, I'll often have the option of reverting back by restoring a system image from when I was running a previous version of Windows.
73, John W1JA
cleanrf
Post by cleanrf »
I started a thread a few months ago about my 10-E occasionally splattering badly and people report it has an echo sound. This is SSB and AM mode. Running windows 10 pro. I believe this has only happened with pure signal on. I read through this thread but not sure I saw an actual solution. Also, has anyone found a fix for not being able to see the DUP screen while using PS? Any help is greatly appreciated
You would not find a "solution" in this topic because nobody has reported the problem but you. Recommend you go back to your original "warble" topic and pick up where you left off:
https://apache-labs.com/community/viewt ... f=9&t=3602
There is no known problem with the DUP display while using PureSignal. This would appear to be another problem that might be unique to you. It might also possibly be unique to the 10E. Are there any other 10E users who have experienced this problem?
nubbyless
Post by nubbyless »
Just for reference The dup screen on my 10e does not work with protocol 1 either i had posted about this some time back.
It does work fine with protocol 2 but with protocol 2 i must run manual calibration as pure signal auto calibrate is unreliable on the 10e with protocol 2.
vk1hx
Post by vk1hx »
I've been reading up on all the experienced bugs and tweaks. I'm running Thetis v2.8.11 and just noticed that when deactivating PS-A and then reactivating PS-A the "ATT" value changes back to the max value of 31. If I power Thetis off or close the program and relaunch it, the ATT value for PS feedback level is back at 31. I don't seem to be able to set a value and keep it there (Thetis isn't saving the last set ATT value on close, power off or deactivating / reactivating PS-A). I either have to manually change the ATT value before I TX or PS has to recal on first TX.
I've tried DB resets, reinstalls etc and the behaviour is the same. Am I missing something with the latest version of Thetis? Under version 2.6.9.0, I did not notice this issue.
Regards
Phil - VK1HX
73, Phil - VK1HX
That behavior is by design. The only safe approach is for the ATT value to always revert to 31 anytime PS is started (or restarted) after being deactivated. That way the PS receiver is assured of minimum input signal strength to start with, given that the system has no way of knowing ahead of time how much power you're going to be feeding the PS receiver.
