So ... not seeing a whole lot of discussion here on how to connect a transverter let alone if it can be done properly.
I have an 8000DLE and I was looking at adding 23cm EME using a Q5 transverter. I see the TX out jack for a transverter but looking through the 8K manual I don't see any info on what it is supplying or how to configure it! Likewise where do I connect the RX? it has been suggested that the only way is through RX2, correct?
I'm using 3.4.9 currently. Very happy with it. How do I set this up - including if possible having the display correctly show the frequency (1296 Mhz)?
The Q5 has either a separate IF in or single IF in. The IF is going to be 28Mhz. I'd prefer using the TRVR TX out jack as that is a fixed level and I hope decent IMD levels whereas if I use one of the 3 antenna jacks and the amp its IMD isn't that great at low power levels. But I don't think I want to use RX2 as the RX input.
HELP?! (if I missed info in the manual my apologies)
K9RX (you're welcome to write direct at my call at arrl email address)
- Board index Hardware & Software Interfacing Transverters
- Search
- It is currently Thu Jan 08, 2026 6:33 am
- All times are UTC
23cm transverter to 8000DLE
Jump to
- Apache Labs News
- ↳ Apache Labs News
- Client Software Discussion
- ↳ Thetis
- ↳ piHPSDR
- ↳ PowerSDR mRX
- ↳ linHPSDR
- ↳ SDR Console
- ↳ All Other Clients
- ↳ Digital ("Virtual") Audio
- ↳ Amplifiers & Tuners
- ↳ Transverters
- ↳ PC's & Homebrew Hardware
- Firmware Discussion
- ↳ Upgrading/Downgrading
- ↳ Orion Firmware (200D)
- ↳ Angelia Firmware (100D)
- ↳ Legacy Yahoo Group Files
- Other Topics
- Equipment Exchange
