k4fmx wrote:i also have to select B1 send button on the virtual channel to get the mike audio into thetis. But when it is selected here it causes the noise on wsjt. Disabling B1 send button on vertial channel 1 kills the noise.
You do not, repeat NOT, need the B1 send button activated on the Thetis virtual channel assigned to Thetis to get microphone audio in.
If you cannot get microphone audio into Thetis without the B1 send on the Thetis virtual channel activated then you are doing something wrong.
I took my (rather complex) Voicemeeter setup and stripped it down to to its barest essentials to prove it works. I can make a video if you like to further prove it.
Assuming your microphone is on hardware input 1, and your speakers are on hardware output A1, for phone:
1. On hardware input 1 channel you need ONLY the SINGLE Bx send activated, where "x" is 1, 2 or 3, depending on which virtual channel Thetis VAC1 is assigned to.
2. On the virtual channel assigned to Thetis you need ONLY the A1 send activated to send audio to the A1 hardware output.
That's it.
You should never, EVER activate a send that is the same as the channel it is on UNLESS you are using the Patch Inserts/Voicemeeter Insert Virtual ASIO to loop audio out to and back from a DAW or other VST host.
This works perfectly for phone. It is all you need for phone. If this is not working for you then you have done something else wrong. Please excuse the fact that I have Thetis on B3 instead of B1, but I really didn't want to change my channel assignments as well for this example.
- Capture2.JPG (324.78 KiB) Viewed 18281 times
