Holding off on releasing 21d for a few days, so I can at least do some more testing.
However, I have just put up a vid which was meant to be a quick short one, but ended up being 30 mins
https://www.youtube.com/watch?v=aRPxGm09Q_c
yep this is correct Ernst. They are applied per tx profile, and should recover to the last used profile when restarting so unsure why not acting as expected.oe3ide wrote:AFAIK the values are stored in the TX-profile. Try to save the corresponding TX-Profile.I have one small point for your list. It concerns the VAC RX level in DIGU mode. The last value used is saved and displayed after restarting thetis, but not applied
I have the same problem... filter line in waterfall (disabled in setup), keeps reapearing after each Thetis restartDL8LAQ wrote:Hi Richie,
I hate colored lines and filter overlay in the waterfall. Since one of the 21 versions I have to check/uncheck "Waterfall - Show Zero Line" and "Waterfall - Show Filter " after every start of Thetis to get rid of it. I did export database and save transmit profile, but every day I have to check/uncheck...
Thanks for your fantastic work
That is correct with the TX-Profile and the value is correct restored on the screen, but the level itselve is not set as on screen shown. It seems to be 0 dB instead the shown -16. When you change the slider one step, the value is set correct. Hope you can see it in the short video.AFAIK the values are stored in the TX-profile. Try to save the corresponding TX-Profile.
Unfortunatly the video is private.That is correct with the TX-Profile and the value is correct restored on the screen, but the level itselve is not set as on screen shown. It seems to be 0 dB instead the shown -16. When you change the slider one step, the value is set correct. Hope you can see it in the short video.
Sorry, my fault. Now video should work and I will do some more testing.Unfortunatly the video is private.
Can you send me your database.xml file? It is probably something to do with the rather annoying method of state recovery. It goes something like....DF2LH wrote:Hi Ernst
73, Thomas
yeah it is perhaps the reason that PD3LK mentioned. A bug was introduced in 21c that prevented the display thread from closing in all cases which could result in thetis still running in the task list. Has been resolved for 21d.W9BHI wrote:Richie,
I found the install files and pasted the new 21C zip files.
I am using the 64 bit version (just like the old one)
I held the cntrl button down and it said it would copy the database files.
I did the restart and the new version loads but when I press start nothing happens.
I am obviously doing something wrong here.
Help needed.
Don W9BHI
Someone needs to write a parser for that cty.dat, to build suitable regex stringoe3ide wrote:A quick check:
1A0 Sovereign Military Order of Malta
4O Montenegro
4U1ITU 4UnITU United Nations Geneva
4U1SCO UNESCO, Paris F
4U1VIC United Nations Vienna OE
I guess the best way would be to use the cty.dat file.
http://www.country-files.com/bigcty/
I decided at the time not to implement it Gary due to the work involved. It will all change over time going forward anyway when the RX's are split into their own displays so it wont be an issue. Also, one could ask why do we have panafall / panadapter and waterfall modes? If the splitter is moved right to the top, it is waterfall, if it is moved right to the bottom it becomes panadapter, somewhere in between it is panafall.NC3Z wrote:Ritchie, back a few versions you added a method to infinitely adjust the split between the Pan section and the Waterfall section of Panafall for RX1. Can that feature be extended to when RX2 is enabled? Besides it not working on the second Panafall, when RX2 is enabled it reverts the RX1 Panafall back to 50/50.
I use RX2 a lot and I find a smaller waterfall (about 25%) preferred.
That would be the ultimate in versatility, and be more streamlined. Will wait for that day. Thanks.ramdor wrote: Also, one could ask why do we have panafall / panadapter and waterfall modes? If the splitter is moved right to the top, it is waterfall, if it is moved right to the bottom it becomes panadapter, somewhere in between it is panafall.
I think you have assigned DDC3 (RX2) to ADC0. If you change ATT on RX1, then the ADC0 attenuator is active and DDC2 (RX1) is correcting the gain reading, but not DDC3 (RX2). RX2 does not know that the rx path is attenuated now.DO2ZA Erwin wrote:Hallo Ritchie and All,
I am not shure if this is a bug, or my Mistake: If I start RX 2 and than give with the RX1 S-ATT say 9 db Att, the Gain-line from RX 1 goes up, but on RX 2 the Gain-Line stays but the Noise/Stations in Panadapter goes down?? Also the S-Meter RX 2 goes down.
If I use the RX 2 S-ATT, the Gain-Line, the Spectrumlevel and the S-Meter goes up.
I noticed this today with RX 1 S-ATT on 12 db, then start RX 2 and nothing to hear.
With the other ATT is it the same.
73 Erwin
1) Get the old TAPR version running again and setup. All running connecting to the radio etc. Close it down. Short cut on desktop etc.W9BHI wrote:Richie,
I started with the 21a download and got that working.
Now up to 21c and it is working.
I made a shortcut to the home screen but it doesn't work.
I have run the executable from the data file.
Ideas?
Don W9BHI
I have confirmed this and it is definitely a bug. The proper behavior would be for RX1 and RX2 to check and see if they are both on ADC0 or ADC1. If they are, then the ATT or S-ATT setting for both RX's should be tied at the hip, because they are both using the same hardware at that point.DL8LAQ wrote:I think you have assigned DDC3 (RX2) to ADC0. If you change ATT on RX1, then the ADC0 attenuator is active and DDC2 (RX1) is correcting the gain reading, but not DDC3 (RX2). RX2 does not know that the rx path is attenuated now.DO2ZA Erwin wrote:Hallo Ritchie and All,
73 Erwin
That is not neccessarily a bug, but should be on Richie's list for the new Thetis design.
I cant replicate this. Changing a high/low/width on filter setup form, for any selected (yellow button) filter updates them. If for example the one in use on the spectral display is Var1 and Var1 is yellow in the filter setup form, any change is instantly reflected visually, at least on mine.w-u-2-o wrote:Another small bug: when changing the Var 1 or Var 2 filter settings the passband overlay on the spectral display is not updated in a live fashion. You have to click onto another filter preset and then back to see the overlay width update.
If I hover with the mouse over the numbers and turn the mouse wheel the numbers do change but the passband overlay does not. I must first click on the number to move the the passband overlay.w-u-2-o wrote:Another small bug: when changing the Var 1 or Var 2 filter settings the passband overlay on the spectral display is not updated in a live fashion. You have to click onto another filter preset and then back to see the overlay width update.
your mouse wheel changes are so small. Zoom the filter to max and you will see that it updates.DL8LAQ wrote:If I hover with the mouse over the numbers and turn the mouse wheel the numbers do change but the passband overlay does not. I must click on the number to move the the passband overlay.w-u-2-o wrote:Another small bug: when changing the Var 1 or Var 2 filter settings the passband overlay on the spectral display is not updated in a live fashion. You have to click onto another filter preset and then back to see the overlay width update.
