I have an Anan 100d using the PowerSDR mRX 3.4.9 and I have put an antenna for the 60m band and when trying to transmit I get an error "Out Of Band" The frequency 5,354600 Mhz a combination with your TX filter setting (200,2900) are not within the band specification for your region 1.
How can I do to transmit the same thing happens to me in CW mode
73`s Rafael EA8TK
Consult Tx 60m band
Re: Consult Tx 60m band
I had the same problem with "Region 1". Now I am using "Germany", that works for me.
https://www.oe3ide.com
Thanks for answering Ernst
This afternoon I will try changing the country to see if it works, I know that with Spain it did not work either
73`s Rafael EA8TK
73`s Rafael EA8TK
Thanks Ernt, for the information I have used the extended region and it works without problems
73`s Rafael EA8TK
73`s Rafael EA8TK
