Locked
@ramdor
Richie--the Two Tone CAT command is broken.
Two Tone is set to "Use Drive Slider". TUN is set to "Use Fixed Drive".
Using the 2TON button on the UI works as expected: drive power is achieved.
Using zztu1; 2TON is produced at the tune power setting.
If TUN is changed to "Use Drive Slider" then zztu1; asserts drive power, so it would appear that zztu1; is following the TUN settings and not the Two Tone settings while the 2TON UI button is following the proper settings.
If it matters, hardware is an 8000DLE.
Now just waiting for Rob to update button and slider packs ;)
dl5tt
Post by dl5tt »
oe3ide wrote:Josef, you can copy
and
Ernst,
tnx for the hint, its working.
2022-04-17 20_34_17-Window.png (2.79 KiB) Viewed 26235 times
73 Josef
w-u-2-o wrote:@ramdor
Quick look at the code and ZZTU does tune, not 2Tone.
Do you want ZZUT ?
Neither RX1 or RX2 are receiving any signal for me. Attached are screenshots of my ADC tab and the generated ErrorLog.
Radio is black case 7000DLE MKII running Protocol 2.
Do you want ZZUT ?
Argh! :( Yes, I meant "ZZUT", my apologies. I'm not dyslexic, really!
K1LSB wrote:Richie,
uninstall through windows, go into the thetis install folder, remove any dll's that are left. It looks like your install process did not put the new channelmaster.dll in there which has that new function SetAudioAmpEnable.
w-u-2-o wrote:Argh! :( Yes, I meant "ZZUT", my apologies. I'm not dyslexic, really!
yes replicated here, will look to fix it this evening if I can stay awake ;)
KA5KKT
Post by KA5KKT »
I have a curious installation / startup problem beginning approximately with V2.9.0.
Upon clicking the Thetis icon, the splash screen will open and progress with Loading Settings down to about 8 or 7 seconds. At that time installation activity ceases.
Leaving it at that stage and again starting Thetis a warning of 'other Thetis instances running' pops up. Clicking Yes to continue allows it to continue to move forward. At that time error messages regarding enabling CAT on COM1 appear. Clicking through about 3 instances of that warning allows Thetis to then open. A 2nd instance of Thetis appears in the Apps section of the Task Manager. Clicking Power allows Thetis to then run. Then closing Splash under the 1st instance of Thetis and End Task then closes the 1 instance.
The 2nd issuance of Thetis seems to continue to run okay. Perhaps I haven't achieved a complete uninstall of Thetis prior to the later fresh install.
Please pardon me if this has been addressed elsewhere.
Thoughts..?
Dick - KA5KKT
PS 7000DLE MKII - Thetis 2.09.01
@Dick - KA5KKT
1) reboot
2) uninstall
3) check folders
C:\Program Files\OpenHPSDR\Thetis
or
C:\Program Files (x86)\OpenHPSDR\Thetis
have no lingering dlls
4) reinstall
5) run up thetis and leave it start
If it is stuck again, make sure there are no popup windows behind the splash screen, by hovering over Thetis taskbar icon to see if any other windows are there
if nothing and still stuck, check task manager for Thetis.exe. If in list end task
check for Errorlog.txt in C:\Users\<user>\AppData\Roaming\OpenHPSDR\Thetis-x64 or C:\Users\Richie\AppData\Roaming\OpenHPSDR\Thetis
Post by W1AEX »
Tricked you Scott! I updated all the slider packs last week. The bad news is that the web hosting server out in California appears to be down and apparently has been for most of the day so w1aex.com is currently dead. No word on when it will come back up. :cry:
Rob
Network Issues
3 hours ago
2022-04-17 14:30 EST
Some servers (sXXX, ws01-ws09, c100/c101, and VPS) are experiencing some connectivity issues that may affect the ability of clients to access services/accounts on these servers.
This has been identified by our server health team, and they are working to resolve the issue as soon as possible.
Thank you for your patience and cooperation in regard to troubleshooting this issue. We will post further updates on this page until the issue is resolved.
Thanks, Rob!
Post by W1AEX »
My host server is back up so feel free to download any of the slider packs you want/need to add the new TUNE slider. The packs are available near the bottom of the "Skins" page at:
http://www.w1aex.com/hpsdr/hpsdr.html
Ernie
Post by Ernie »
TCI between Thetis and RF-Kit is working!
Thanks Richie!
Ernie
W2FMU
W1AEX wrote:My host server is back up so feel free to download any of the slider packs you want/need to add the new TUNE slider. The packs are available near the bottom of the "Skins" page at:
looking good Rob. cheers for updating.
Ernie wrote:TCI between Thetis and RF-Kit is working!
Thanks Richie!
Ernie
W2FMU
Ah ha !! that is great news Ernie. Fab ! Yeah is was brilliant that Ernst reached out to the RF-kit folks to find out what they required.
KA5KKT
Post by KA5KKT »
ramdor wrote:@Dick - KA5KKT
1) reboot
2) uninstall
3) check folders
or
4) reinstall
Thanks, Richie.
I'll give it a go after the NASCAR race concludes. (US 'Stock Car' Racing)
Dick - KA5KKT
Dave30019
Post by Dave30019 »
TCI is now working with RFKit amp & Thetis.
The Best just got Better.
Thanks Ritchie,
Dave
k4em
DL8LAQ
Post by DL8LAQ »
Using rev. 4 now TCI with RF-Kit PA ist working. Nice!
But I have a problem with rx attentuator. Several times now after transition from tx to rx the ATT (RX1) is at maximum, but that is not indicated. ATT display still shows 0. I have to switch ATT to get attenuation to 0 again.
The problem does not happen in QSK mode. Back to SEMI the ATT is at max again.
It happens also in SSB or FM.
RX2 is attenuated in the same way. Switching RX2 ATT brings gain back to 0 on both RX1 and RX2.
It happens on 20m, 10, but not on other bands.
It think I should build a new database.
DL8LAQ wrote:Using rev. 4 now TCI with RF-Kit PA ist working. Nice!
it might be an issue with the new attenuation implementation, I will do some testing later this afternoon. Perhaps some more reports will come in. Can you try to replicate and construct a procedure to make it happen on demand?
yes, i have replicated here, working a fix now
DL8LAQ
Post by DL8LAQ »
it just happens and is a permanent bug. I will try to replicate the problem with a clean database now.
Edit: No problem with a clean db. Now I have to change to my preferred settings.
DL8LAQ wrote:Hi Richie,
it is related to having the same adc set for both ddc2 and ddc3 in your case with 7000.
I am still working the fix.
Richie--the ADC/ATT/RX combinations are many, as you know. If you'd like to post a list of tests for people to verify functionality on the various hardware types, Hermes to 8000, and people ran through the list, would that be helpful to you?
Well any anomalies that people notice should include a report of what has happened, the method they use to replicate it, the radio model, and screenshot of the DDC/ADC page.
Norbert's issue is an issue for everyone, I have fixed it here, but still testing. It is related to the same adc's being used for the rx1 and rx2 ddc. It incorrectly modifies the TXatt.
DL8LAQ
Post by DL8LAQ »
ramdor wrote: it is related to having the same adc set for both ddc2 and ddc3 in your case with 7000.
Ok, I will check that with the previously used database.
Attached are the ADC settings. I don't use a 2nd antenna, so both rx are tied to ADC0.
Edit: Yes, using the previous database and default ADC settings the problem is gone!
DL8LAQ wrote: Edit: Yes, using the previous database and default ADC settings the problem is gone!
yes, thanks for confirming that, exactly what I replicated here. I will be rebuilding the installers in about 30 mins.
PRE-RELEASE 2.9.0.4 updated
Uninstall, and re-install if you have used 2.9.0.4 previously !
https://github.com/ramdor/Thetis-2.9.0/ ... .9.0.4-pre
Has been updated with fixes for the ATT issue where RX1 + RX2 use the same ADC. Also added GridMin to NoiseFloor option which is early work in progress.
DL8LAQ
Post by DL8LAQ »
Deinstalled prev ver, installed new version, but the bug is still in here! I will try later with clean db. Have to leave for ice cream and Liqueur
tasting.
"Adjust Min to Noise Floor" is a beautiful feature!
DL8LAQ wrote:Deinstalled prev ver, installed new version, but the bug is still in here! I will try later with clean db. Have to leave for ice cream and Liqueur
tasting.
can you send me your db? enjoy the tasting :)
EA1DAV
Post by EA1DAV »
May be I am wrong, but this measuremet is dB and not dBm.
Not sure what PBNP is.
Locked
