Setup view pane not visible.
WA6TMJ
Post by WA6TMJ »
Greeting everyone!
First off I want to say Thank You to all of the Thetis team in making an AWESOME program to run on my 8000DLE!!! Just Fabulous!!
Every time an update comes out it's like having a NEW radio!!
I know the Thetis program is awesome but I think I am having a Windoze problem.... Win 10 Home 21H1 19043.1586..
When I have the Thetis program open and want to open the Setup pane its nowhere to be found on either of my screens.
In the task bar I can see the Thetis box and the setup box when I move the mouse over the Thetis task Icon.
But when I try to click on the Setup pane it does nothing.
I tried minimizing Thetis panel to find the setup view pane but nothing!
I got this problem somehow in Thetis 2.9.03 and was hoping that it would be fixed when I uninstalled 03 and install 2.9.05.
But no....
I really think this is a windoze registry issue for the Setup pane display position.
I uninstalled 05 and went into the registry to delete all registry related to Thetis. (that was a lot).
So now have 05 up and running again but I can't make any changes until I can see the Setup window pane. Puff gone...
All other view panes, memory, wave, equalizer, xvtrs... are fine and can be seen and I can make changes.
Thank for everyone's help!!
Very frustrating when you can't see the setup view!
Re: Setup view pane not visible.
Thetis should attempt to bring a 'hidden' off screen window into view. However, if this is not happening, the info the following video might help.
Vid : https://youtu.be/8aBSHl8o6Yg
WA6TMJ
Post by WA6TMJ »
Now THAT WAS AWESOME!!!
Fixed!!
Thank You Sir!!!
I LOVE Thetis!!!
WA6TMJ wrote:Now THAT WAS AWESOME!!!
Fixed!!
Thank You Sir!!!
I LOVE Thetis!!!
which method did you use? the cursor pressing to 'drive' it around, or the reset of the values in the database?
WA6TMJ
Post by WA6TMJ »
I used the cursor method.
Worked great!!
