Seq errors after PC upgrade
vk3amp
Post by vk3amp »
I have been using thetis 2.9.0.6 for a few months now and has been working well.
Today I upgraded my PC to the latest generation. I7-12700. After the install I turned on my new PC but unfortunately I was unable to connect to the radio. It seems when I click the power button it connects to the radio but nothing happens. I can see the seq error 256 flashing constantly. I am getting no sound nor does the waterfall work.
Here is a link to a video to better explain what's going on.
https://linksharing.samsungcloud.com/xRVqzEyq8vPQ
So for I have tried reinstalling Thetis but it made no difference. I am at a loss and have no idea why the hardware upgrade has caused this issue.
Any help would be appreciated.
Re: Seq errors after PC upgrade
Did you swap the CPU in the PC or is this an entirely new PC?
If it was a CPU swap, what was the old CPU?
What version of Windows are you running?
vk3amp
Post by vk3amp »
It's was a complete upgrade.
CPU, motherboard and ram.
I am running windows 11.
The Old system was an i7-6700.
I'm suspecting it may have something to do with the onboard network card.
vk3amp wrote:It's was a complete upgrade.
That's good, so we know it is a fresh OS that is built properly for the system. Nice upgrade from that 6700!
That makes a lot of sense. I've had similar problems with Killer brand NICs (Qualcomm chipset). Is it one of those?
This might be a good opportunity/excuse to put the ANAN on its own, dedicated NIC.
vk3amp
Post by vk3amp »
The motherboard is a Gigabyte Z690 Aorus Elite which has a Realtek® 2.5GbE LAN chip (2.5 Gbps / 1 Gbps / 100 Mbps).
I have both the PC and the radio going into a Cisco gigabit switch.
A very quick Google search produces a frighteningly large number of results discussing problems with the Realtek 2.5G NIC on a variety of motherboards including yours.
It may simply be easier to buy a dedicated Intel GigE NIC, USB3 or PCIE, disable the motherboard NIC in BIOS, and be done with it.
I agree with Scott , a one or two port dedicated NIC is a great addition.
ea3aqr
Post by ea3aqr »
I've been using a Realtek 2.5G NIC without any problem for years.
My motherboard has 2 NICS, and for me Realtek is more stable than Intel when using Thetis
Maybe you Realtek 2.5 folks should compare driver versions. It could be as simple as using a different driver version. There was a lot of that discussed in the Google search as a method to fix problems.
ea3aqr
Post by ea3aqr »
I'm on an AMD platform.
Realtek PCIe 2.5GbE Family Controller
Driver version 1125.7.318.2022
But worked flawesly with all previous driver versions.
