Connections with Alpha 9500
JJ4SDR
Post by JJ4SDR »
I am the second owner of an Alpha 9500 (model year circa 2010, from I understand) and I will operate it from my PC. This would be really an attractive feature as I am operating another amp from my PC right now and I like it a lot.
I just need to locate a web page from which I can download the "Alpha Remote (AR) AR9500 PC application software as the amp didn't come with a CD. If I understand correctly the original owner didn't operate the amp from a PC.
I assume that the 9 pin DB connector ("OC OUTPUTS") on my ANAN 7000 DLE MKII would be the RS-232C connection needed for the exciter and the amp to talk to each other. Will the amp be able to detect the frequency the exciter is on without RF sensing? I have posted this question on qrz.com as well. Any recommendations for a high quality straight-through cable?
Happy New Year!
Re: Connections with Alpha 9500
JJ4SDR wrote:I just need to locate a web page from which I can download the "Alpha Remote (AR) AR9500 PC application software as the amp didn't come with a CD. If I understand correctly the original owner didn't operate the amp from a PC.
Your Google-Fu must really be failing you. Googling "alpha 9500" returns the following link as the very first result: https://www.alpharfsystems.com/?p=1480 Everything you need is there.
NEGATIVE. How is an OC output connector in any way an RS232 port??? Other than Apache decided to use a DE9 connector for this so that it looks like a serial port, something that can obviously be confusing.
You will need to attach to an RS232 COM port on your PC and provision that in Thetis CAT setup. The Alpha would be set up to use Kenwood protocol.
I haven't read the amp manual, but it it can poll for Kenwood CAT responses then the answer is yes.
JJ4SDR
Post by JJ4SDR »
Yes on google :lol:
I keep forgetting that the radio resides on the PC :roll:
Best!
