Ahhhh..... Miguel..... Hello, hello....
Hope you're well.....
I'm feeling guilty. Hope I didn't infect you or your setup!
But what I know, I'm NOT alone. I know another OM. Now 2.
Before I posted my issue, I did research. "Shut Down" "Task Manager" to solve my problem.
I expected some posts but nope.... nothing.
Look at my funny screenshot. App is closed on Desktop but NOT in Task Manager.:
- taskmanager.jpg (25.4 KiB) Viewed 5140 times
In English: "Thetis.exe is running correctly"
Scott:
Actually, one idea: what happens if you run Thetis as administrator? Change the properties of the Thetis .exe, or change the properties of the shortcut you use to launch Thetis.
My standard user has admin rights, THETIS.EXE and the file/directory also got full read/write right's.
Maybe I'm completely wrong, but rights work, or they don't. It works sporadically. Sometimes after 5, after 10 attempts. Sometimes it doesn't work for a whole week.
- Zwischenablage02.jpg (27.12 KiB) Viewed 5140 times
mike b :
Sorry to hear that you're giving up. It's not the solution for me. I'm more an experimenter. Different settings and profiles. Using OC`s, all CAT ports and vy individual PA Settings for QRPP to feed my LDMOS Amp. And of course, all the audio settings for phone. Plus plus plus.
My station is operated remotely. In that case, it has to work reliably.
In the long run, it just gets annoying. I need to be able to rely on settings changes being saved reliably. It's not just about ending the task with another click. Otherwise, there are far too many parameters for me to check and repeatedly set manually with every restart. OC and AMP settings are not to be trifled with.
That's why I wish so much to find someone who knows more than me to get this problem under control in the long term.
Thanks to everybody!
Oliver
(I`m not that win specialist and of course not a Thetis Pro User, even I started with PWRSDR in 2008...... so please sorry for the QRM)
