Good day, everyone.
I apologize if this has already been covered in another thread. I did look and what I found didn't work for me.
Every time I Start Thetis I have to manually go to setup/audio and click "Enable VAC 1", and then go and unclick "Allow PTT to override/bypass VAC for Phone".
Is there a way to set this so that it does not revert back each time?
Would it be an "Export Database" type function or "Export Current Profile" in the Transmit tab?
Your assistance is appreciated.
Walt
VAC1 audio setup
Re: VAC1 audio setup
Set it up the way you want, then save your transmit profile. It will save your VAC settings in the profile.
Make sure the auto save options for transmit profile are turned off so you don't accidentally screw up your settings.
The band stack registers will remember the transmit profile so if you are using different profiles here and there be aware of that.
Many thanks!!
Got it fixed. I was looking in the wrong direction.
'73
Walt
'73
Walt
Thanks from me, too. I'm still learning.
Ed
Ed
